Kubota RTV1140 Diesel Transmission wont pull hill
   / Kubota RTV1140 Diesel Transmission wont pull hill #1
TB65s
Spiro, OK
Kubota 1140
Hello,
We have 12 of these Kubotas and 3 of them with around 1,500 to 2,500 hours on them are to the point where they run great on level ground but when put on a hill they just wont pull the hill. We have been to 2 different dealers and have been following their suggestions but nothing has worked yet.
We have adjusted valve, replaced charge pump, put new squash plates, changed plate and the reliefs added springs, charge pump pressure at idle is 100psi, etc.
Unlike the diesel engines that can be found anywhere the transmissions are scarce and any info for them.
Do you have any suggestions on what we can do to repair them ?
Thanks Tim
2014 Nissan Versa Note Hatchback (A51694)
2014 Nissan Versa...
Kenworth Tri Axle Dump (A47384)
Kenworth Tri Axle...
1985 International 1754 Material Spreader Dump Truck (A51692)
1985 International...
Yale 3,500lb Electric Forklift (A51691)
Yale 3,500lb...
2018 DODGE RAM 3500 LARAMIE SERVICE TRUCK (A51406)
2018 DODGE RAM...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
