Kubota RTV1140 Diesel Transmission wont pull hill
   / Kubota RTV1140 Diesel Transmission wont pull hill #1
TB65s
Spiro, OK
Kubota 1140
Hello,
We have 12 of these Kubotas and 3 of them with around 1,500 to 2,500 hours on them are to the point where they run great on level ground but when put on a hill they just wont pull the hill. We have been to 2 different dealers and have been following their suggestions but nothing has worked yet.
We have adjusted valve, replaced charge pump, put new squash plates, changed plate and the reliefs added springs, charge pump pressure at idle is 100psi, etc.
Unlike the diesel engines that can be found anywhere the transmissions are scarce and any info for them.
Do you have any suggestions on what we can do to repair them ?
Thanks Tim
2000 Mack CH613 Day Cab Winch Truck (A53117)
2000 Mack CH613...
2020 Kubota SVL75-2 (A50123)
2020 Kubota...
2017 Taylor-Dunn B0-248-36 Electric Utility Cart (A50324)
2017 Taylor-Dunn...
INMY Manual Landing Gear (A51692)
INMY Manual...
2013 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2013 FORD F-150 XL...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
