Kubota RTV-X900 Dump Body Question
   / Kubota RTV-X900 Dump Body Question #1
bobsphotos
ME
JD 3320 Ford 641 Ford 861 Kubota L3400
I am looking at the Kubota RTV-X900 to use for cleaning a cow barn, horse barn, and a goat barn on a small farm. The large majority of what we clean ends up being pine shavings that we use for bedding. I would like to increase the dump capacity with sideboards because the pine shavings have more volume than weight.
Has anyone out there added sideboards to their Kubota side by side ?
Thanks,
Bob W
   / Kubota RTV-X900 Dump Body Question #2
I have a 1120X RTV. I built some bed extensions for mine. Here it is
   / Kubota RTV-X900 Dump Body Question #5
I also fabricated framework that attaches with 4 screws to the bed extensions for a tarp cover. I had a local tarp shop make the cover
Very nice work !
   / Kubota RTV-X900 Dump Body Question #7
Thanks. The tarp bows were made from an old trampoline that my grandkids didn’t use anymore and was in disrepair. It worked out well in the repurposing
   / Kubota RTV-X900 Dump Body Question #9
If you are going to haul manure in it the 1st thing I would recommend is caulking the seams around the bed floor and a good quality spray on bedliner to prevent rust. As I'm sure you know there is a lot of acidity in the urine and manure so even with shavings rust can be a problem.
I'm on my second RTV and found that the paint is not the greatest and rust is a problem.
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
2016 KENWORTH T680 TANDEM AXLE MID ROOF SLEEPER TRUCK (A52576)
2016 KENWORTH T680...
2025 New/Unused Wolverine Brush Cutter (A51573)
2025 New/Unused...
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50324)
2013 Vermeer V800...
Target Ecoline Walk-Behind Concrete Saw (A49461)
Target Ecoline...
2022 Case IH Magnum 340 AFS MFWD Tractor (A53342)
2022 Case IH...
