Kubota rtv x1140
   / Kubota rtv x1140 #1
rblackmon25
kubota rtv x1140
We received a lot of rain the last couple of days and due to low land my Kubota was under water for a couple of days. I am not a mechanic by any means, but would like some ideas on where should I start with repairs. The battery stayed charged, but engine doesn't say anything.
Thanks
   / Kubota rtv x1140 #2
How far underwater?
DO NOT try starting until you provide details. Your engine may be hydrolocked!
   / Kubota rtv x1140 #3
Thanks
Yikes. Welcome from Missouri.
Lots of intelligence on the forum that can help.
MoKelly
   / Kubota rtv x1140 #4
Again how far under water?
Inside cab?
Over hood?
Over roof?
It matters as different systems are effected by how much of the rig sat in water.
For instances if water got into the cab but only a bit at the floor board, you likely only need to let everything dry out. If it was over the hood or cab, it is likely a total loss as the water has gone throughout all the motor, transmission and all electronics, cost of replacement of these systems is probably greater than replacement cost.
My examples are the 2 extremes just to let you understand why how high water got is important to understand.
Until this assessment is determined, I recommend doing nothing than dragging it out of the mud. DO NOT ATTEMPT TO CRANK IT! Flood waters are renown for being nasty dirty, if fluids are contaminated, you do not want that spread through the motor (oil and/or coolant), transmission, differential.
201930 (A54756)
201930 (A54756)
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A54607)
2018 FREIGHTLINER...
2018 JLG 4045R 40ft Electric Scissor Lift (A55787)
2018 JLG 4045R...
2013 JOHN DEERE 470G LC EXCAVATOR (A52705)
2013 JOHN DEERE...
2015 FORD E350 16FT BOX TRUCK (A54607)
2015 FORD E350...
