Kubota RTV Remotes Will it run a splitter?
   / Kubota RTV Remotes Will it run a splitter? #1
horsinaround
down the road a bit
Kubota L5740 Kubota F3080
I am just about to pull the trigger on a Kubota RTV. Does anyone know or has anyone run a splitter off of the bed dump pump. They have the connections to run "implements" but a splitter is not listed as one of the options. With a little rigging I am sure it could be done, but will the pump output be adequate? That little diesel engine would sure make a splitter go with the proper set up.
Thanks.
   / Kubota RTV Remotes Will it run a splitter? #2
There is no doubt in my mind that it will run a splitter however, the cycle times will be slow, the duty cycle will be low and the power is questionable.
They have a model that is setup for continous duty applications that includes a return filter, oil cooler, and second set of auxillarys for work tools. This setup would be much better suited to splitting IMO.
   / Kubota RTV Remotes Will it run a splitter? #3
The output is right about 6 gpm at 2200lbs if I recall, its about standard for rear remotes on a small tractor. As was said, its not made for continuous duty. If you want to run the remotes non-stop you need to add the hydraulic cooler kit. Till you go though that expense and buy a splitter you'll spend the same $$ as buying a self contained unit.
UNUSED JCT 72" HYD TILLER (A57193)
UNUSED JCT 72" HYD...
2023 Fat Truck 2.8C Amphibious AWD Off-Road Utility Vehicle (A55853)
2023 Fat Truck...
UNUSED JCT 84" HYD DOZER BLADE (A57193)
UNUSED JCT 84" HYD...
UNUSED FUTURE D39 39" HYD TRENCHER (A57193)
UNUSED FUTURE D39...
2002 22Ft Harris Kayot Boat with 2025 Homemade T/A Boat Trailer (A55853)
2002 22Ft Harris...
110 GALLON L SHAPE FUEL TANK (A57192)
110 GALLON L SHAPE...
