Kubota RTV 900
   / Kubota RTV 900 #1
72crh
Kubota RTV900
I have a 2005 kubota rtv900. The 4wd does not engage. 2 wheel works fine. The lever and linkage all seem to work ok. It worked fine 2 months ago but does not engage now. What do I need to check??
   / Kubota RTV 900 #2
Your front driveshaft spline may be stripped or one of your CV axle shaft splines to one of your front wheels may be stripped.
RTV 4wd issue
   / Kubota RTV 900
Thanks ruffdog, I just replaced both front struts and cv axels in front. Still not working,
2019 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2019 FREIGHTLINER...
2007 FORD F650 XL SUPER DUTY FUEL & LUBE TRUCK (A51406)
2007 FORD F650 XL...
Bush Hog 9670 8FT Pull Type No Till Grain Drill (A55218)
Bush Hog 9670 8FT...
2012 Nissan Rogue (A50324)
2012 Nissan Rogue...
