Kubota RTV 900 won't go into gear
   / Kubota RTV 900 won't go into gear #1
rcbor187
Cali
Kubota RTV 900
We have a Kubota RTV 900 and it has been working so-so. It would have trouble starting, finding neutral was somewhat difficult. eventually after going into H M and L it would finally start. IMG_0345.JPGIMG_0346.JPG
I made sure that the linkage was good and working properly. I opened up the back and realized that something did not seem right. Any tips on what might be happening would be greatly appreciated.
   / Kubota RTV 900 won't go into gear #2
we had one do something similar.it was like the linkage was froze up.dealer fixed it,he said something inside wears out and to fix it a washer had to be welded on something.works like new now
i See this is a somewhat common issue. Is there any how to guides for the fix? Thanks
   / Kubota RTV 900 won't go into gear #4
Might clean it up good and pull the shifter plate off and resetting the forks, had the one on my RTV-1100 pop out of the grooves from someone forcing the shifter without releasing the pressure on the gears.
David
right on thanks. i saw the guy on youtube did his but the video is awefully shaky. I am going to try and do this myself.
   / Kubota RTV 900 won't go into gear #6
It sure wont hurt that engine a bit to use a high pressure hose and some soap and water to wash off the dirt and grease. I hose the dirt off mine frequently. Removing the gunk keeps everything running cooler also. Cant help you with the shift problem.
Small bar fell into transmission... been digging in there with a magnet. Can't get it. Any suggestions greatly appreciated! Thank you
Going to try and drain tranny fluid see if I can get it out through the train plug **** this blows
got the shaft out but it seems to be sheered off. looking for a parts diagram online but cant seem to find it.
2025 INDUSTRIAS AMERICA FT510 5' X 10' HYD DUMP TL (A51247)
2025 INDUSTRIAS...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A52377)
2015 Chevrolet...
(INOP) CATERPILLAR 320 EXCAVATOR (A51247)
(INOP) CATERPILLAR...
1992 SYLVAN 20' PONTOON BOAT (A51247)
1992 SYLVAN 20'...
2010 VANGUARD 53x102 DRY VAN (A53426)
2010 VANGUARD...
UNUSED MOWER KING SSFCAG Y HD HYD AUGER (A51248)
UNUSED MOWER KING...
