Kubota RTV 900 vs Kubota RTV 500
   / Kubota RTV 900 vs Kubota RTV 500 #1
busypenguin
Todd, Pa.
None
First time user here.
I'm hoping someone can help me out. I'm contemplating buying a Kubota RTV 900 or 500 but can't make up my mind. I live in Pa. I intend to use the machine mainly for plowing snow. Pa. hasn't gotten hit with a major snow storm (knock on wood) for quite a while and I guess my main hickup with buying a 600 is would it have enough power compared to the 900 if we did have a major snow storm?
Busypenguin
   / Kubota RTV 900 vs Kubota RTV 500 #2
Welcome to TBN. You should post this question in the ATV & Utility forum. I have an RTV500, but I do not use it for snowplowing. In high range, the RTV500 is a little under powered. However, in low range it is pretty much unstoppable. There several members that use the RTV500 for plowing. If you do a search on the RTV500/900 in the ATV & Utility Vehicle forum you will find lots of information.
Thanks Stonehaller, I will check out that forum.
   / Kubota RTV 900 vs Kubota RTV 500 #4
Just going by the numbers, the 900 has more power and should be able to sustain a higher speed when plowing. It also weighs 50% more than the 500, it's diesel vs. gas in the 500, so there should be quite a bit more pushing power. But the 500 seems such a convenient small package, I would love to have one. Either choice should be great.
   / Kubota RTV 900 vs Kubota RTV 500 #5
I have the RTV 900 and it is great for pulling. I don't do snow plowing but I have used it pulling a drag harrow, pulling up trees and dragging out logs from forest. It has plenty of power in L and M but not so much in H as that is too high speed for pulling. I also like the hydraulic dump bed, I can load it fully with rocks or dirt and dump it on an idle without a strain at all. I cant say anything for the 500 as I have never even looked at one but the diesel engine in the 900 is a definite plus for longevity and power. I suspect that the $$$$ will be much more for the 900 than the 500 but then you get what you pay for in extra size, weigh, power and comfort. I like that the 900 is high enough off the ground for good ground clearance but is still easy to get in and out of. When I first got mine, the wife wouldn't even use it as it was too "big and obnoxious" as she was used to driving her electric golf cart. After a few weeks she finally decided to drive it a bit and it does take some getting used to with the sudden stopping when you take your foot off the go pedal. Now she rarely uses her cart unless I have the RTV out working with it. I have about 290 hours on it so far with not one problem, just regular oil and filter changes as per the schedule.
I won't have a lot of uses for this other than snow plowing for some 8 full time senior citizens who reside here in a small community in western Pa. I think a 900 would be overkill, and I don't have any other equipment that uses diesel fuel. I have only come to this conclusion after reading responses sent from members of this web-site. I think the 900 would be a better choice if I had more property and had more work for it. I really don't think I can justify the cost vs. the work for it at this point in time. Thanks for your input.
   / Kubota RTV 900 vs Kubota RTV 500 #7
I rather thought that the price tag on the 900 would have you choke a bit. They are outrageously priced. I bought mine used 2 years old and only 68 hours on it so it was basically new. The price was $8500 so I got a very good deal especially with the cost now. The were $11500 new at the time but it seems Kubota has added a couple grand to the cost now. I am sure the 500 will work for plowing snow as I have seen ATVs do it with small 3 foot blades.
Thanks for all your input.
2013 Honda CR-Z EX Hatchback (A53424)
2013 Honda CR-Z EX...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
2011 Nissan Rogue SUV (A53424)
2011 Nissan Rogue...
2013 Cadillac SRX (A50324)
2013 Cadillac SRX...
2011 John Deere 120D (A47477)
2011 John Deere...
JOHN DEERE 2150 TRACTOR (A51406)
JOHN DEERE 2150...
