Rat Rod Mac
- Joined
- Oct 22, 2006
- Messages
- 177
I have a Kubota RTV 900 and this morning it started acting up so I thought I would run this past you guys to see if you have had anything like this happen to you. While going up a hill on the township road it started bog down, so I stopped and it went back to idling and then I hit the fuel pedal and away we went for another fifty to hundred feet and it did it again. I dropped it down a gear, but once again it did it. I was able to get it back to the barn, now to figure out what's wrong. Here's a better example. If you have ever driven a dump truck or anything with a stick shift and you start up a hill, the engine starts to bog down and at a point you have to shift to a lower gear, but if you don't the engine will jerk a couple of times and then shut off. Ok, that's kind of what this is doing, but of course I don't let it die. I stop and it comes down to an idle and then I go again for a hundred feet and it does it again. I'm thinking either fuel filter, clogged up exhaust or possibly fuel pump, but fuel pump you would think it would either work or not. Anyone have this happed to you? Thanks. RRM
