Kubota RTV 1140 cpx
   / Kubota RTV 1140 cpx #1
Pat2288
Kubota RTV 1140 cpx
Trying to diagnose kubota why it doesn稚 move forward and reverse in 2 wd but it moves in 4wd need help if anyone has had this problem before thanks.
   / Kubota RTV 1140 cpx #2
:welcome:
Welcome to the forum!
I'm going to move this thread over to our Kubota section to see if we can find you an answer.
   / Kubota RTV 1140 cpx #3
my buddy had same problem and both the back hubs were stripped out.its a common problem on them from what we were told
   / Kubota RTV 1140 cpx #4
I have a RTV1140 that I've owned for 8 years with zero issues other than learning how to depress brake pedal to shift gears, apply emergency brake and hand pressure on lever from 2 to 4wd till it just slides in or do it stopped. I've been a member on this forum for about 12 years and never heard of this issue personally or here on this Kubota forum.
   / Kubota RTV 1140 cpx #5
If problem isn't stripped rear hub then I'll guess broken rear axle or spider gears/shafts in rear differential.
   / Kubota RTV 1140 cpx #6
Yup^^
The rear hubs on X900, X1120 and X1140 are the same and I have not seen a stripped hub yet. The rear hub recall pertained to a material change in the hub housing.
   / Kubota RTV 1140 cpx #7
Check the 2 to 4 shift linkage, probably not moving the full distance needed
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
2017 Chevrolet Express Box Van, VIN # 1GB0GRFF9H1305955 (A51572)
2017 Chevrolet...
2015 Crane Carrier Co. Low Entry New Way 31ASL 31Yd Side Loader Garbage Truck (A51692)
2015 Crane Carrier...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A53472)
2016 KBH...
2011 Mack CHU613 T/A Wet Kit Day Cab Truck Tractor (A51692)
2011 Mack CHU613...
