Kubota RTV 1140 cpx
   / Kubota RTV 1140 cpx #1
Pat2288
Kubota RTV 1140 cpx
Trying to diagnose kubota why it doesn稚 move forward and reverse in 2 wd but it moves in 4wd need help if anyone has had this problem before thanks.
   / Kubota RTV 1140 cpx #2
:welcome:
Welcome to the forum!
I'm going to move this thread over to our Kubota section to see if we can find you an answer.
   / Kubota RTV 1140 cpx #3
my buddy had same problem and both the back hubs were stripped out.its a common problem on them from what we were told
   / Kubota RTV 1140 cpx #4
I have a RTV1140 that I've owned for 8 years with zero issues other than learning how to depress brake pedal to shift gears, apply emergency brake and hand pressure on lever from 2 to 4wd till it just slides in or do it stopped. I've been a member on this forum for about 12 years and never heard of this issue personally or here on this Kubota forum.
   / Kubota RTV 1140 cpx #5
If problem isn't stripped rear hub then I'll guess broken rear axle or spider gears/shafts in rear differential.
   / Kubota RTV 1140 cpx #6
Yup^^
The rear hubs on X900, X1120 and X1140 are the same and I have not seen a stripped hub yet. The rear hub recall pertained to a material change in the hub housing.
   / Kubota RTV 1140 cpx #7
Check the 2 to 4 shift linkage, probably not moving the full distance needed
2014 D&P WELDING 16FT PRESSURE WASH TRAILER (A52472)
2014 D&P WELDING...
2017 John Deere HPX615E Gator Utility Cart (A51691)
2017 John Deere...
2017 Kubota KX080-4 Mini Excavator (A51573)
2017 Kubota...
ROME LN-16 LOT NUMBER 131 (A53084)
ROME LN-16 LOT...
2014 KOMATSU PC490 LC-10 CRAWLER EXCAVATOR (A52576)
2014 KOMATSU PC490...
BOBCAT 260 WELDER/GENERATOR (A52472)
BOBCAT 260...
