kubota rtv 1100 hydraulic problems
   / kubota rtv 1100 hydraulic problems #1
01hunter570
my Kubota 1100 developed a high pressure leak in the hose coming off the hyd. pump going to the hyd control lever. this lever doubles as the box hoist and snow plow angle lever I replaced the hose and now the plow won't angle. i'm thinking the electronic valve that switches the flow of hydraulic fluid from one to the other isn't working but was wondering if it could possibly be air locked. when in the box position works fine in plow angle position plow starts to angle then stops and the box goes up. any thoughts on this would be appreciated thanks 01hunter570
   / kubota rtv 1100 hydraulic problems #2
Probably air locked. Start by running all the controls several times to full stop in both directions. If that doesn’t work crack one of the hoses you just replaced and start it- reminder this is over 2000psi- it’s slightly lose not nearly off! The second method will run a bit of fluid out and should get rid of the air lock.
If neither of these two work you may have got some junk in one of the lines.
49" X 79" EXPANDED METAL RAMP GATE (A51247)
49" X 79" EXPANDED...
2016 Case IH True Tandem 345 (A50123)
2016 Case IH True...
MARS AIR DOORS TAN BANK (A51248)
MARS AIR DOORS TAN...
(INOP) KAWASAKI MULE 1000 UTV (A51247)
(INOP) KAWASAKI...
2000 WINNEBAGO FORD F550 RV (A52472)
2000 WINNEBAGO...
2004 Ford E-350 Passenger Van (A51692)
2004 Ford E-350...
