kubota rtv 1100 hydraulic problems
   / kubota rtv 1100 hydraulic problems #1
01hunter570
Bronze Member
my Kubota 1100 developed a high pressure leak in the hose coming off the hyd. pump going to the hyd control lever. this lever doubles as the box hoist and snow plow angle lever I replaced the hose and now the plow won't angle. i'm thinking the electronic valve that switches the flow of hydraulic fluid from one to the other isn't working but was wondering if it could possibly be air locked. when in the box position works fine in plow angle position plow starts to angle then stops and the box goes up. any thoughts on this would be appreciated thanks 01hunter570
   / kubota rtv 1100 hydraulic problems #2
Probably air locked. Start by running all the controls several times to full stop in both directions. If that doesn’t work crack one of the hoses you just replaced and start it- reminder this is over 2000psi- it’s slightly lose not nearly off! The second method will run a bit of fluid out and should get rid of the air lock.
If neither of these two work you may have got some junk in one of the lines.
2016 FREIGHTLINER M2 WATER TRUCK (A51247)
2016 FREIGHTLINER...
(1) UNUSED 5200# DROP AXLE W/ BRAKES (A51247)
(1) UNUSED 5200#...
2023 JACTO ARBUS-1000 LOT NUMBER 65 (A53084)
2023 JACTO...
2007 GEHL CTL-60 SKID STEER (A51246)
2007 GEHL CTL-60...
2012 John Deere 7230R (A53472)
2012 John Deere...
2009 GMC Passenger Van, Vortec Engine (A52384)
2009 GMC Passenger...
