3-Point Hitch Kubota rear went up fine but won't come down
   / Kubota rear went up fine but won't come down #1
kina
whitby on
Kubota B7610
Kubota rear went up fine but won't come down.
   / Kubota rear went up fine but won't come down #2
I am going to take some WAG's here.. Three Point Hitch went up? and now wont come down?... does it have any weight on it? Is the drop rate control valve under the seat opened enough to allow fluid flow ? (turn counter clockwise to open the valve).. just guessing here, but that is my "best guess"
James K0UA
   / Kubota rear went up fine but won't come down #3
:welcome:
Are you talking about 3 pt hitch ? Check that knob under your seat and when it comes down watch "feet" and make sure no-one gets hurt.
Boone
   / Kubota rear went up fine but won't come down #4
James you ain't lost it your still quick on the draw. :D
Boone
   / Kubota rear went up fine but won't come down #5
Boone
Yep, sometimes not much to go on to solve the puzzle... but I did the best I could:)
James K0UA
   / Kubota rear went up fine but won't come down #6
Check see if something caught/holding arms etc.
Sorry! its a 3 pt hitch and has a snow blower on the back. Tried the knob under the seat, still nothing. Thanks for the help (sarcasm and all)
   / Kubota rear went up fine but won't come down #8
Really? :confused:
   / Kubota rear went up fine but won't come down #9
If your hyd system is open center system, the cyl is locked in the neutral position.
So, I have to ask if you pushed the 3pt lever down all the way, and is the 3pt lever working correctly..
This action releases the fluid in the 3pt cyl, and the descent knob will adjust the descent rate.
Even if the knob is opened, there may be debris/rust in the descent orifice.
You could also have some mechanical binding in the linkage.
Is this the first time it has done this?
   / Kubota rear went up fine but won't come down #10
New or old tractor, what specific model, did it work OK before this, how long have you had it, etc., etc. These folks would like to help you, but they can't look at your tractor so the more information you can supply, the more helpful they can be. Just a thought.
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
2015 Nissan Pathfinder SUV (A50324)
2015 Nissan...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2015 VOLVO VNL TANDEM AXLE DAY CAB (A52576)
2015 VOLVO VNL...
2016 Ottawa Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, 33,000 ... (A52748)
2016 Ottawa Yard...
44509 (A51692)
44509 (A51692)
