Mowing Kubota RCK60B23BX mower deck problem
   / Kubota RCK60B23BX mower deck problem #1
waanderson
Carnesville Ga
Kubota Bx24D JD950
I have a Kubota BX-24 with a Kubota RCK60B23BX mower deck that I use to mow 6-8 acres of pasture every few weeks. I do this so that the owls and hawks can manage the reptiles and rodents that move in when the grass gets over a foot tall. My problem is that the pulley covers don't keep grass and twigs from entering the belt and gearbox area in the center of the mower deck. I recently had a twig jam a pulley and subsequently damaged the drive belt. My question is has anyone fabricated a cover to keep the center area free of debris?, and if you have would you share your solution. I suspect that I'm not the only one that has had this problem.
Thanks
bill a.
   / Kubota RCK60B23BX mower deck problem #2
Thanks
bill a.
New BX25D here and approaching 50 hours...I just yesterday, took the black covers off mine to grease the spindles and noticed some debris under the covers.
I just hosed the area clean,, greased the spindles and will probably just keep doing the same after mowing each week. I don't know of any additional covers to keep this from happening bt if anyone does, this is the place to ask. For the first 40+ hours the debris was not terrible...my last mower, a Simplicity would load up with clippings in that area...after mowing each week I also blow off the entire tractor with my backpack blower before hosing it off...that helps!
Just one of those areas that will catch clippings and debris, I guess.
   / Kubota RCK60B23BX mower deck problem #3
Covers? I took them off a long time ago, LOL. I use an electric leaf blower when done to blow out the clippings. I don't think I've ever had a twig get jammed in there, however. I have a B2710 with (I think) an RCK60 deck, 500 hours.
2016 FREIGHTLINER CASCADIA SLEEPER (A57880)
2016 FREIGHTLINER...
UNUSED FUTURE FT-180H HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
2014 Ford F250 4x4 Crew Cab Pickup Truck (A55973)
2014 Ford F250 4x4...
2008 Sterling Acterra Ambulance (A56858)
2008 Sterling...
2013 Dodge Charger Passenger Car, VIN # 2C3CDXAT8DH646721 (A57453)
2013 Dodge Charger...
