Mowing kubota RC60 - 24B mower deck
   / kubota RC60 - 24B mower deck #11
I have an old brochure of a 7300HSD. On the back page is a little box with some mid-mount mower specs. It says that the adjustment of the cutting height for the RCK60-24B mower deck is made by gauge wheel setting. Hope this clears things up. BTW, when I asked about this issue before I decided for a mid-mount vs a rear, the dealer suggested that I could set the cutting height, but diring the wet season I could just suspend the deck from the hitch using the pto position control. I'm not sure if this will affect the deck and/or mounting points over time due to wear, but its worth a try.
PaulT
Soon to be the pround owner of a brand spankin' new Kubota 2710
   / kubota RC60 - 24B mower deck #12
Orange uses the gauge wheels to support the entire weight of the deck. The tractor should not be supporting the weight of the deck at all. There are two gauge wheels on the front on each side (swivels), and a double gauge wheel at the rear of the deck in the center. Additionally, there are two "anti-scalp" wheels on the rear of the deck on each side, and a third anti-scalp wheel in the front center (now you should be TOTALLY CONFUSED). The gauge wheels support the deck and the anti-scalp wheels should 'float' 1/2" above the ground.
Steve
"Amateurs built the Ark. . . . . . . .Professionals built the Titanic"
   / kubota RC60 - 24B mower deck #13
Guys,I have to agree with Mike.When we bought our B2150 with 72" mid-mount mower,I was having trouble with the deck wanting to "sag" in the center of the mower.This was in 1994,I asked the lead mechanic at our dealership for his advice,by the way he's been working on Kubotas since 1976,and his reply was to set the deck up EXACTLY as Mike has discribed.He said it will not harm the linkage to carry some of the weight of the deck.Well,I went home and made the adjustments,set the stop on the 3-point,and the mower performed perfectly,as level a cut as you could ask for.Since then we have a B2710 with the same deck,and I set it up the very same way,with the same results.The gauge wheels still roll on the ground all the time,but they carry a lot less weight.We bought a BX2200,and started mowing with it about 3 weeks ago,it has a "true" suspended deck,a design I think Kubota robbed from Deere.Regardless,the gauge wheels on the deck simply keep it from scalping.
   / kubota RC60 - 24B mower deck #14
You have probably solved your problem by now, however I had the same thing happen on my new 2910 and wanted to share it. I owned a TC29 prior to this with a full floating deck and did not have the sod tearing problem.The reason I beleive this happens other than damp soil is the difference in rear wheel configuration. The N/H has a narrow double rack on the rear of the deck that pivots with the deck, while the Kubota has heavy duty corner mounted gauge wheels that swivel (at least on the 72" decks). I encountered the sod tearing problem when changing direction from forward to reverse on uneven ground. The dealer suggested what others have mentioned here already, take a bit of the weight off the wheels by setting the control a bit higher, making it a suspended deck in essence /w3tcompact/icons/shocked.gif. That will work, it also will limit the travel of the deck and on uneven ground, effecting the quality of the cut. My 4100 did not provide nearly as good a cut as a full floater does except on perfectly flat ground. I found that over greasing the gauge wheels will tighten them up on the shaft exacerbating the sod tearing problem. Also, check the tolerance of the wheels on the shaft as it pertains to the washers and cotter pin that holds them in place. I found the mechanism to be extermely tight and by inserting a smaller pin, relieved some pressure on the gauge wheel allowing it to spin freely. I am sure in time this would have corrected itself due to normal wear on the assembly, but I was able to elimimnate the sod tearing completely without suspending the deck at all. Also, in looking at the 72" Kubota deck, I see no way that it would ever "sag" as mentioned in this thread.
   / kubota RC60 - 24B mower deck #15
Bayrat,
Since you've owned all three (NH/JD & Kubota) - which one does the best job mowing? How did you manage to own all three models? Too small (4100), too big (TC29) and just right (2910)? Just wondering.
PowerMax
   / kubota RC60 - 24B mower deck #16
Powermax,
The N/H and Kubota are equally as good on various type of terrain. The Deere does not do as well due to the suspended deck that does not follow contours as closely, a minor difference though. And you are correct, the 4100 was a bit too small for my needs. As for the N/H, I had planned on keeping through retirement, but due to the number of problems that kept developing over a year and a half, decided to go back to Kubota.
   / kubota RC60 - 24B mower deck #17
Thanks, Bayrat. I'm in a similar situation. The TC21, 4100 and 7500 are just a little too small and not enough hp for my needs. I really liked the TC25/29, but am very concerned about the 2500# wieght and maneuverability around the obstacles in my yard. I have some areas with some very uneven terrain, swails, steep banks, etc. The B2910 seems to be an excellent compromise for me. I have also been checking out the Agco ST30 to complicate matters. Any suggestions???
PowerMax
2010 Chevrolet Traverse SUV (A56859)
2010 Chevrolet...
Push Mower (A55973)
Push Mower (A55973)
2003 KOBELCO SK235SRLC EXCAVATOR (A57880)
2003 KOBELCO...
2014 Walker Compactor (A55787)
2014 Walker...
1983 INTERNATIONAL S SERIES WATER TRUCK (A57192)
1983 INTERNATIONAL...
1997 Perkins 75KW Towable Diesel Generator (A56857)
1997 Perkins 75KW...
