Kubota quick connect question
   / Kubota quick connect question #1
bulldog02
What kind of quick connect did kubota use before they went to the skid steer type? My dad's tractor has one that has a bar across the front of his loader that sets into a set of hooks on his attachments and then pins in at the bottom of the attachment. I need to build one that I can weld onto a plate that to fit my tractor. My New kubota has the skid steer type. Hope I'm not confusing everyone, but I would like to build one for my tractor so I can use his attachments. Thanks in advance
   / Kubota quick connect question #2
What you describe I believe is the Kubota proprietary pin on type. They still use that type on the "B" series with their optional pin on bucket and pallet forks.
you wouldnt know where i could find the plans on something like that do ya?
   / Kubota quick connect question #4
ATI sells a pin setup for the B series,, 175.00 I think.. If you take that and weld it to a blank SS plate and you should have it,,
Ill try and get a pic of it today and let yall look. Cant seem to find one anywhere?
   / Kubota quick connect question #6
For my m5700 you could get it with the bucket pinned on the arms, a kubota designed QD pinned on the arms, or a skid steer style QD on the arms. Mine was purchased used with a kubota Qd like you descibe. I would not look at getting a adapter plate to go between the two due to added stress but rather getting the kubota style pin on for your arms. I looked at getting the skid steer style disconnect to swap out on mine and it was reasonable priced. I would call kubota dealer with the model number of your loader as some of the tractors was available with more than one model loader.
   / Kubota quick connect question #7
I priced a QC like the one your refering to from my local dealer and it was 240 dollars. It was the only one offered for mine, but I decided to build a SSQA for mine instead. As for plans for your dad's style just get all the measurments you need from his.
2019 FORD TRANSIT 350HD VAN (A53426)
2019 FORD TRANSIT...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
2008 Nissan Sentra Sedan (A51694)
2008 Nissan Sentra...
UNUSED FUTURE FT-BC63 63" HYD BRUSH CUTTER (A51248)
UNUSED FUTURE...
RYOBI 2900 PSI GAS PRESSURE WASHER (A51248)
RYOBI 2900 PSI GAS...
2020 Chevrolet Tahoe SUV (A51694)
2020 Chevrolet...
