Kubota Quick connect coupler
   / Kubota Quick connect coupler #1
gregjo1948
Newark Valley,NY
Ford 2000 Industrial- Ford Jubilee-Ford 3400-IH 404-Farmal 504-Ih 284-Case 310
I recently bought a Kubota front loader LA344. It has a quick connect/disconnect coupler attaching the hydraulic lines to the tractor. I didn't get the part of the coupler that stays with the tractor when the loader is removed. I have the coupler part that has the locking handle that stays with the loader. Anyone know where I can get the coupler "receiver" that stays with the tractor. It has 4 quick attach couplers in line mounted on a plate. I don't need the control valve unit. thank you, gregjo1948
   / Kubota Quick connect coupler #2
As a rough guess I'll say the Kubota dealer should be able to provide it. Otherwise you could check with a hydraulic shop.
   / Kubota Quick connect coupler #3
Snap a photo. The couplers are identified as “male” or “female”. I assume when you say receiver you mean female?
   / Kubota Quick connect coupler #4
I believe he's talking about one of those "one hand, connect under pressure" setups that most manufacturers offer?? His tractor doesn't have it.
I don't know what Kubota tractor model that loader would come on?? If you know that you could then do a parts search on that tractor to see what's available? Or as Roadworthy said, talk to a Kubota dealer.
Were it me,,, I'd remove the fancy connector box and put four simple quick couplers on my tractor and convert the loader hoses to matching couplers?
   / Kubota Quick connect coupler #5
Plus one but if you do, don't forget to color code the lines and connectors. I use colored electrical tape for that.
That gang connector thing is a gimmick.
I think I will probably go with the quick couplers. I found the part I was looking for and it is $170.00 plus. thanks for the replies and help, gregjo1948
Genie GTH-844 (A50123)
2012 UNVERFERTH 10-INCH FRONT WHEEL SPACER FOR 10 BOLT HUB (A53473)
2012 UNVERFERTH...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
UNUSED FUTURE SF60 HYD MAST W/ 60" FORKS (A51248)
UNUSED FUTURE SF60...
UNUSED CHERY INDUSTRIAL 14' BI-PARTING IRON GATE (A51248)
UNUSED CHERY...
1988 BASSTRACKER 20' PONTOON BOAT (A51247)
1988 BASSTRACKER...
