Kubota Possible Purchase
/ Kubota Possible Purchase #1
Texasmark
Elite Member
N. Texas
Ford: '88 3910 Series II, '80 3600, '65 3000; '07 6530C Branson with FEL, 2020 LS MT225S. Case-IH 395 and 895 with cab. All Diesels
Saw a 2002, 2wd, rear remotes, cab, 2000 hrs with loader, M6800. Never had a Kubota and have heard that parts are pricy. Thinking about purchasing from owner. Owner says AC and heater in cab work great. Looks to be in good shape with a couple of pictures. No other comments. Should I be leery?
/ Kubota Possible Purchase #2
No more leary than with any other used tractor purchase. Kubota makes quality machinery, but any brand can be subjected to abuse or poor maintenance.
/ Kubota Possible Purchase #3
Not having 4x4 would be really tough for me. Not saying it would not work, but been around a lot of 2x4 tractors and backhoe and they seemed to get stuck or just useless on any slimy, muddy, hill or wet grass. Very frustrating. Would never go that route again. But that's just me, but I live in NH, so terrain is much different then Texas. But you do have mud.
/ Kubota Possible Purchase #4
Mark, what will you be using it for? Flat, dry terrain is fine with 2WD. Is it a hydraulic shuttle?
My experience with Kubota has been mixed good/bad.
My experience has been that if you use a Kubota M series at its max ability, it will wear out fast. Obviously, so will any tractor brand, but Kubotas are on the lighter side for their HP rating. I ran my M126X and M135X reasonably hard and they did not hold up as well as I expected. I had PTO issues and steering issues to name a few.
Parts aren’t that bad, but injectors were very expensive.
/ Kubota Possible Purchase #5
I have both. Anything in the future will be 4wd
/ Kubota Possible Purchase #7
/ Kubota Possible Purchase #8
Buy NH if you want pricey parts and wait times
Thanks for the thoughtful replies. I don't like the 2wd either. I have 2 4wd tractors and the extra axle pulling has helped me enough times to know that it is desired. I was thinking about this as the power source for my JD 375 4x6 baler primarily but the asking price is pretty high just to offset having to deal with a heavy and cumbersome PTO shaft on the baler.
/ Kubota Possible Purchase #10
I hear ya on that!
It’s every farmers desire to have one tractor per attachment lol
Since it’s primarily pulling a baler, it would probably only be getting used in dry conditions, so 2WD would be ok, unless you have steep hills.
I need 4WD because of hills and some soft areas.
I don’t know the asking price, but I get you 100% on heavy PTO shafts. The ones on my square baler & CX-15 are class 6 and heavy !
/ Kubota Possible Purchase #11
If you plan to use the FEL on that 2WD tractor, keep in mind that a loaded bucket takes weight off the rear tires and you loose traction. You need a LOT of rear ballast to compensate.
Depending on what ballast you use, you may have to detach that heavy bailer PTO driveshaft anyway.
2008 FORD E- 350 S/A MOBILE PET GROOMING VAN (A59914)
2008 FORD E- 350...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
New/Unused 3-in-1 Quick Attach Frame (A65583)
New/Unused 3-in-1...
Woods 15ft. Batwing Mower (A65640)
Woods 15ft...
2000 Volvo Semi (A66285)
2000 Volvo Semi...
(INOP) 2022 MACK MD6 WATER TRUCK (A64280)
(INOP) 2022 MACK...
