Buying Advice Kubota Paint Fade Fixed
   / Kubota Paint Fade Fixed #11
Most likely the first batch of 2017 models will peel the paint right off like the Fords and Chevys did in the late 80s.
   / Kubota Paint Fade Fixed #12
I've noticed it a lot more in the RTV's that I have looked at, also a lot of rust. It looks like they didn't clean the sheet metal before priming, if they even primed, them. The plastic front ends are always nice and shiny but the metal, including a lot of frames are very poor.
   / Kubota Paint Fade Fixed #13
I致e not noticed this to be a problem except on old Kubotas that were stored outside. I致e seen plenty of 90s model vehicles with peeling clear coat so automotive grade is very reassuring. Even if you had the best paint in the world the sun still destroys plastic, hydraulic hoses, tires, and the seat. If you care about your equipment you really need to keep it out of the sun. My 2011 JD backhoe has likely been stored outside it痴 whole life until I bought it last year and it has quite a bit of sun damage.
SO...ooo TRUE!
I am looking for a relatively low hour used Kubota L48 yr. 2004-2009.
Can't seem to find anything that has been stored inside.
   / Kubota Paint Fade Fixed #14
I'm not sure if this is what you are referring to, but for a few years there were problems with the primer, so that paint wouldn't stick to it. In order to fix it you had to have your vehicle stripped down to the bare metal.
UNUSED X-STAR 101" X 20' LOADING RAMP (A51243)
UNUSED X-STAR 101"...
Ih 490 Disk (A50514)
2020 CATERPILLAR 289D3 SKID STEER (A51242)
2020 CATERPILLAR...
2007 FREIGHTLINER BUSINESS CLASS M2 DUMP TRUCK (A51406)
2007 FREIGHTLINER...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
UNUSED AGT NT18K EXCAVATOR (A51243)
UNUSED AGT NT18K...
