Kubota or mahindra
   / Kubota or mahindra #351
I'm gonna do all I can in that regard but my 4 month on and 4 month off job messes with all of it.
Do you know a fellow up your way named Tim Herbert I used to be in electric line school with him many years ago..
   / Kubota or mahindra #352
It doesn't ring a bell. I've only lived here a few years.
   / Kubota or mahindra #353
So, 4 months on, 4 months off, it is actually only one year? :unsure:
   / Kubota or mahindra #356
Been reading the ontrack posts and mostly disagree with them. I looked at Kubota and Mahindra and having had a JD garden tractor I dismissed JD, plastic underengineered light weight in the subcompacts. The Kubota in the 20 hp range does not have a cat 1 3 point hitch vs Mahindra Which does. The Kubota had way to much plastic to crack at 7,000’. The dealer was, well really didn’t exist. The hydraulics are minuscule. They cant even lift the front wheels with the FEL or lift the FEL both at idle.
The eMax22 was significantly heavier with large cast axles, stronger and thicker chassis with much better lifting capability. There really is no comparison. Mahindra dealer did some warranty work recently, leaking rear axle seal, $150 pick up and delivery charge, he’s only 45 miles away but thats 7,000’ down and about a 90 minute one way drive, a bargain, pickup and returned in 3 days. Offered to buy at my purchase price - 4.5 years old 600 hrs.
Mostly use it for snow and landscape work. Added a 2,000# linear actuator for rear blade, rear camera, rear and top led lamps. Chain all 4. I’ve pulled a Ford 1 ton dully high centered, all wheels off the ground on a large icy berm with ease, didn’t spin a wheel. 900# lift with fell 1100# 3 point hitch.
2022 Ford F-150 XL Pickup Truck, VIN: 1FTVFX1E84NFB46867, Crew Cab, 4 x 4, 3.5 L EcoBoost Gas (A59076)
2022 Ford F-150 XL...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A56857)
2023 Caterpillar...
202473 (A54757)
202473 (A54757)
New/Unused Electric Golf Cart (A57453)
New/Unused...
2012 MACK GU713 (A58214)
2012 MACK GU713...
2007 Amkus Rescue System (A56857)
2007 Amkus Rescue...
