Kubota or Kioti - Which Model
/ Kubota or Kioti - Which Model #21
IF you are going to be messing around with ponds then IMO you need an excavator. Something that will keep the machine on high and dry ground and a long enough reach to make it into the pond.
Well worth considering, we've mucked ponds out with our tractors, but will rent an excavator if we ever need to do it again. Some pond work can be done with a tractor, but more of it can be done easier with an excavator at least in our situation. It was kinda fun though.
/ Kubota or Kioti - Which Model #22
I think anything above maybe 30hp will do the job, but the bigger you go, the faster most of the work will get done...it comes down to how important time is to you, and what your budget will handle.
As far as brands go, both companies make great machines. The best thing you can do is get yourself some seat time on several of them, and see what you think. Things that don't bother me might really annoy you, and vice-versa. It'll come down to where things are placed, the seat, etc, etc.
When Kioti came out with the NX line I spent some time in one and was pretty impressed at what you get for your money. The fit and finish was excellent (this was a cab model) and it appeared to be very solidly built. If I was buying something in the 40-60hp range with HST, the NX would be my first choice. I wouldn't turn down a free Kubota, but they tend to run about $10K more for similar performance/features, and there are a lot of things I could do with that $10K. I don't have any doubts as to Kioti quality, and would fully expect thousands of hours of trouble-free service out of one. Any machine can break, but between these two companies I don't see either as being any more likely to have problems.
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A62131)
UNUSED WOLVERINE...
1991 INGERSOLL RAND DD-24 SMOOTH DBL DRUM ROLLER (A62129)
1991 INGERSOLL...
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
2016 Ford F-150 Ext. Cab Pickup Truck (A61568)
2016 Ford F-150...
UNUSED JCT HYD AUGER (A62131)
UNUSED JCT HYD...
2019 Kenworth T880 Tri-Axle Dump Truck (A61568)
2019 Kenworth T880...
