Kubota or John Deere
   / Kubota or John Deere #81
Anyone turn up the fuel on an RTV900?
Any advice & recommendations? Where is the screw?
I did so on my L39 with just a bit of additional torque.
I'm too much of a woos to try that. I've read some threads regarding adding a turbo as well. I think any alteration to add more fuel/air to that engine needs to be monitored closely. The failures I've saw are melted pistons. I'll have my mechanic neighbor look at mine. I'm sure he can tell us how to do it. If so, I'll post a reply with pic.
   / Kubota or John Deere #82
We had near 1500 Lbs in our Rtv 900 squashes it real good and you need to go slow, but it carries its own weight.
I have no way to confirm weight, but I've hauled this type of load many, many times. I use it to fill small ditches that show up in my fields. Best part is pull the handle to unload!!! :)
   / Kubota or John Deere #83
The RTV 900 will carry and dump about 900-1000 lbs depending on how the load is distributed in the bed. It will carry more but can't lift to dump, and even thought I've had I guess 1,500 Lobs of rocks in the bed, that is being mean to the little UTE
   / Kubota or John Deere #84
When I'm hauling dirt or firewood I load with the tailgate open. Shifts the center of the load rearward where it's easier for the hydraulics to dump it. If more will fit on, it's not full. :)
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2013 Ford Edge (A54815)
2013 Ford Edge...
Deere 310L (A53317)
Deere 310L (A53317)
1408 (A57192)
1408 (A57192)
2022 JOHN DEERE 624P WHEEL LOADER (A52709)
2022 JOHN DEERE...
