Comparison Kubota or John Deere
   / Kubota or John Deere #21
I was comparing cab models. John Deere 4066R brochure cab operating weight, 3,737lb. Kubota Grand L6060 cab brochure operating weight 4365lb. A difference of 628lbs of difference. Must have have looked at a different line the first time around. 628lbs does not seem very much now.
That's the weight of an open station Deere. Actually, the Open station is closer to 3900 lbs
   / Kubota or John Deere #22
Sorry for jumping in but this topic is near and dear as it were. I just sold my Kubota L4600 HST with FEL because it was too light to (in my opinion) safely handle the seed drill I hope to acquire this spring. The tractor was said to weigh 3100 lbs or so and the FEL about 650 more. A JD 5045 weighs in around 5,100 plus loader per the books. Also, the Kubota, even the M5640 I almost bought, had exposed tie rods and rubber mud caps in front of the front axles subject to abuse. It cost me right at $800 to replace the tie rod and shield when a buried stump rolled up while pushing a brush pile. (Actually KTAC insurance covered it all except the $250 deductible), even covered the costs to transport to the dealer 60 miles away. The JD has a much stouter front end and most things are behind heavy steel, not in front of it. Anyway ,The newly ordered 5055E with power-reverser and H240 FEL should be here in a few weeks. It weighs the same as the 5045E, but I have learned to find a big enough tractor than step up as far as you can afford. Only wish I could get the 5075!
That's the same weight as the JD 4x20's were, maybe Kubota up their weight a little
   / Kubota or John Deere #23
Both loaders are a little weaker than the rest of the industry, but the Bota loader is a couple hundred lbs stronger than the Deere.
I'm not sure that is a fair statement. John Deere rates their loaders with a standard bucket which, in the case of an H180 loader, is 320 pounds. Also, look at the numbers 18 inches forward of the pivot pins. Many companies don't publish those numbers. You will see if you scrutinize the numbers that the JD 4R series has a more powerful loader than most CUTs. Then take a look at height, reach, and breakout. Then consider that most CUTs don't offer a mechanical self leveling loader as an option., Then consider the quick attach detach of the JD loader. I'm not saying that the JD loader is better straight across the board, but certainly better than most, and it can't be said that they are weaker than the rest of the industry.
   / Kubota or John Deere #24
Right now, my ground is so soggy in the pastures, the heavy tractors are left in the barn. Only the light ones with wide tires are used at this time of year. I like to add weight if I need it and not have to deal with making ruts. You can add weight, but you can't add easily HP to offset the weight. Weight makes a tractor more sluggish in my mind. So it all comes down to what your needs are. If it is a heavy tractor, get a heavy one, just remember, you can't take the weight off. If it is versatility, get a lighter one.
   / Kubota or John Deere #25
Looks like JD did beef up the H180 loader weight specs over the 400x specs, though the loader lifts about 3" lower. They pretty much all use a standard bucket for the measurement... Not a whole lot of weight variations with a 72" wide hunk of metal. Here are the numbers of competing large CUT cab tractors. Note that Deere has the lowest 3pt lift of any the competition (not sure why). Also note, that the TYM, LS, Kioti & Mahindra loaders were not fully represented because they do not post lift numbers at 500mm... However the Mahindra & Kioti loaders list the highest weight lift potential at the pivot pin measurement ... FYI.
TRACTOR----LOADER MODEL---3PT LIFT @24"---LDR LFT @ 500MM----LDR LFT @ PP---LDR LFT height-----LDR LFT 59" @ PP---LDR LFT 59" @ 500mm
Massey 1758----DL130------------3084lbs---------------2056------------------2527-------------113.5"-------------2648-----------------------2299---------------------
Kubota L5740--LA854-------------2980lbs---------------1878------------------2489-------------112.3"-------------3097------------------------2509---------------------
Deere 4066R---HL180nsl---------2500lbs---------------1846------------------2486--------------109"---------------2957-----------------------2022---------------------
Deere 4066R---HL180msl--------2500lbs----------------2178------------------2477-------------109"---------------2944-----------------------2825---------------------
Kubota L6060---LA1055----------2976lbs----------------1784------------------2361-------------112.3"--------------NA-------------------------NA----------------------
Deere 4720------400x------------2500lbs----------------1742------------------2368-------------1128"--------------2701-----------------------2154---------------------
Deere 4720------400cx-----------2500bls----------------2571------------------2383-------------112.8"-------------2696-----------------------2639---------------------
Mahindra 2555---2555CL---------2945lbs----------------N/A-------------------3122-------------115.4"--------------NA--------------------------NA---------------------
Kioti NX6010-----KL6010---------3177lbs----------------N/A-------------------2761-------------108.3"--------------NA--------------------------NA---------------------
TYM T554---------TX55------------2945lbs---------------N/A-------------------2478-------------109.8"--------------NA--------------------------NA----------------------
LS XR4046--------LL4102---------2756lbs----------------N/A-------------------2500--------------96.1"--------------NA--------------------------NA---------------------
   / Kubota or John Deere #26
I have been looking at Kubota Grand L6060 and looking at John Deere 4066R tractors. Horse power is about the same. They are both good tractors I believe. One thing is troubling me. Weight matters with a tractor. A heavier tractor can do more. Kubota Grand L6060 is almost 1000ibs more than the John Deere in the same class. Just wondering why and what you think is the better buy? Thanks
Last early spring looked at the Deere 4066R, the Kubota L6060, the Mahindra 6010, the Massey MF1759 (gear tractor but i was thinking of the MF1758 eHST) and I wound up purchasing a Kioti NX6010. At the time the NX6010 with all options was $20,000 less than the Deere 4066R, and $12,000 less than the Kubota L6060.
I remain pleased with my purchase.
   / Kubota or John Deere #27
Looks like JD did beef up the H180 loader weight specs over the 400x specs, though the loader lifts about 3" lower. They pretty much all use a standard bucket for the measurement... Not a whole lot of weight variations with a 72" wide hunk of metal. Here are the numbers of competing large CUT cab tractors as published (in order of lift weight @ 500mm). Note that Deere has the lowest 3pt lift of any the competition. Also note, that the Kioti & Mahindra loaders were not fully represented because they do not post lift numbers at 500mm... However they do list the highest weight lift potential at the pivot pin measurement ... FYI.
TRACTOR----LOADER MODEL-----3PT LIFT @24"-----LOADER LIFT @ 500MM-----LOADER LIFT @ PINS-----LOADER LIFT HEIGHT
Massey 1758----DL130--------------3084lbs--------------------2056---------------------------2527-------------------113.5"----------
Kubota L5740--LA854---------------2980lbs--------------------1878---------------------------2489--------------------112.3"----------
Deere 4066R---HL180nsl-----------2500lbs---------------------1846---------------------------2486--------------------109"-----------
Kubota L6060---LA1055-------------2976lbs--------------------1784---------------------------2361---------------------112.3"----------
Deere 4720------400x---------------2500lbs--------------------1742---------------------------2368---------------------1128"----------
Mahindra 2555---2555CL------------2945lbs--------------------N/A----------------------------3122---------------------115.4"----------
Kioti NX6010-----KL6010------------3177lbs--------------------N/A----------------------------2761---------------------108.3"---------
TYM T554---------TX55--------------2945lbs--------------------N/A----------------------------2478---------------------109.8"---------
LS XR4046--------LL4102-----------2756lbs---------------------N/A----------------------------2500---------------------96.1"----------
You chose to use the 400x instead of the stronger 400cx, and the H180 NSL instead of the stronger H180 MSL, why?
Even so, your numbers are still lower than the numbers on the deere website. The Deere website list the lift at the pins at 2539.
But why not use the strongest MSL loaders for a comparison? Even with your skewed numbers the only tractor that has significantly more lift is the Mahindra.
What info do you have that proves which manufactures test their loaders with a bucket?
   / Kubota or John Deere #28
Yes, but also how much money have you put into your tractor after purchasing it. It seemed like for a while there it was being worked on. I'd rather spend the money and have it already be ready to go.
   / Kubota or John Deere #29
Yep, I totally agree with you Tom. But I'll add, here on TBN, most owner/operators use their tractors for a small variety of tasks and rarely change the configuration in any way.
   / Kubota or John Deere #30
TSO: Great table in Post #25. I know it required hours of research to prepare and post.
BUSH & BOG 16 BLADE DISC HARROW (A52708)
BUSH & BOG 16...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A55973)
2014 MultiQuip...
2015 Nissan Frontier Ext. Cab Pickup Truck (A56858)
2015 Nissan...
2013 HINO 338 26FT BOX TRUCK (A58018)
2013 HINO 338 26FT...
New/Unused CFG Industrial H12R Mini Excavator (A57453)
New/Unused CFG...
TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET FOR...
