Kubota oil leak
/ Kubota oil leak #1
mac62951
Johnston City IL
Kubota zg23 zero turn
I have a Kubota zg23 zero turn 23hp briggs. There is an oil leak coming from the topside of the engine (around the carb?) running down the back of the engine and hitting the exhaust. Carb gasket?
/ Kubota oil leak #2
What Briggs do you have on there? I've seen an older Vanguard that had a bad carb and loaded the oil with fuel which overfilled it. That caused oil to blow back up through the air intake and ooze from some of the gaskets.
2010 MACK CXU TRI-AXLE (A65643)
2010 MACK CXU...
2017 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2017 Ford F-250...
AGT Top Cat Brush Cutter (A64047)
AGT Top Cat Brush...
2006 Chevrolet C5500 Service Truck, VIN # 1GBE5E3256F423684 (A65563)
2006 Chevrolet...
1994 CHEVROLET GMT-400 EXTENDED CAB TRUCK (A65054)
1994 CHEVROLET...
(30) 3"x9' Steel Posts (A66408)
(30) 3"x9' Steel...
