Kubota MX5800 Top and Tilt
   / Kubota MX5800 Top and Tilt #1
oldafretired
North Idaho
Kubota L3901, MX5800, U55
In order to get the hydraulic tilt cylinder to be in mid stroke when the rear blade is level, I had to use the original right side adjustable lift rod on the left side. The original non adjustable left lift rod had two adjustment holes. One would let the blade tilt a lot to one side and very little on the other, the other hole caused the opposite effect. I needed a length in-between the two. Any problem using the adjustable right rod on the left side?
   / Kubota MX5800 Top and Tilt #2
That's exactly what Brian at FitRiteHydraulics recommends doing.
2011 Ford F-150 Ext. Cab Pickup Truck (A48081)
2011 Ford F-150...
2013 Chevrolet Caprice Sedan (A48082)
2013 Chevrolet...
2025 20ft. G70 Cargo Transport Chain (A48081)
2025 20ft. G70...
2020 Chevrolet Equinox LS SUV (A48082)
2020 Chevrolet...
2018 Toro Sand Pro Bunker Rake with Edger/Broom (A49461)
2018 Toro Sand Pro...
2019 FORD F450 TOW TRUCK (A51222)
2019 FORD F450 TOW...
