Kubota MX5800 Top and Tilt
   / Kubota MX5800 Top and Tilt #1
oldafretired
North Idaho
Kubota L3901, MX5800, U55
In order to get the hydraulic tilt cylinder to be in mid stroke when the rear blade is level, I had to use the original right side adjustable lift rod on the left side. The original non adjustable left lift rod had two adjustment holes. One would let the blade tilt a lot to one side and very little on the other, the other hole caused the opposite effect. I needed a length in-between the two. Any problem using the adjustable right rod on the left side?
   / Kubota MX5800 Top and Tilt #2
That's exactly what Brian at FitRiteHydraulics recommends doing.
71067 (A49346)
71067 (A49346)
1500 Gallon Water / Chemical Tank (A50860)
1500 Gallon Water...
John Deere 4655 Tractor (A50860)
John Deere 4655...
2016 Dodge Challenger SXT Coupe (A48082)
2016 Dodge...
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
2012 Chevrolet Impala Sedan (A48082)
2012 Chevrolet...
