Kubota MX5100 (HT)
   / Kubota MX5100 (HT) #1
PineOak
Montgomery, TX
Kubota MX5100
I own a Kubota MX5100 w/hydrostatic transmission. I suspect I have a "safety switch" problem, because as of yesterday it won't start. Basically, when I turn the key there is no response. The battery is strong, but there is not even the familiar "click" of power reaching the starter. I know there is a safety switch under the seat and as part of the PTO lever, however both of tested OK. Does anyone know if there are others and/or experienced a similar problem?
   / Kubota MX5100 (HT) #2
Not personally familiar with your tractor model. With that said, if I try to start mine with, for example, the shuttle lever in forward/reverse, it still clicks loudly when the key is turned "on", but won't engage the starter when turned to "start". Nothing I can do will eliminate the loud click when turned to on. Sounds like something other than a safey switch??
If you can think of anything else you need me to test I will. Sorry I can't be more help.
   / Kubota MX5100 (HT) #3
Try rocking the hst pedal. It may not think it's in the neutral position.
Thanks for the advice. Turns out it was a loose wire on the PTO lever's safety switch. 3 hours of staring at it and 5 minutes to fix it.
Thanks to all for the advice. As I mentioned above, it was a loose wire on the PTO lever's safety switch. Quick fix.
   / Kubota MX5100 (HT) #6
Good job, better check the rest of those connections.
Good advice. All are secure. As it turns out, the PTO lever switch was the last one I checked, and the last one to check.
   / Kubota MX5100 (HT) #8
Only 3 hours???? I'm never that quick...... Glad you got it fixed!!!
   / Kubota MX5100 (HT) #9
I chased a similar, it was the GST shuttle neutral safety switch. It's been bypassed ever since, I keep forgetting to order a new one...
TMA (A49461)
TMA (A49461)
ECONOLINE TRAILER, INC (A50323)
ECONOLINE TRAILER...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2017 Chevrolet Express Van, VIN # 1GB0GRFF9H1305955 (A51572)
2017 Chevrolet...
2013 Honda CR-Z EX Hatchback (A50324)
2013 Honda CR-Z EX...
