Oil & Fuel Kubota MX5100 Engine Oil
   / Kubota MX5100 Engine Oil #1
loghill
Montrose, CO
Kubota
Does anyone have experience using Rotella T in a Kubota MX5100? The manual seems to say that you shouldn't use it because one of the many Rotella T specs is CJ4. The manual, if I'm understanding it correctly, says that CJ4 oil shouldn't be used because it's intended for DPF (Diesel Particulate Filter) engines. However, checking around with service people at various Kubota dealers, they all think it's okay to use. I can't get a Kubota Corporation service person to answer the phone so far to find out what they say and, if it shouldn't be used, what the risk is in using it. If anybody knows about using Rotella T in this particular engine, I'd appreciate hearing more.
   / Kubota MX5100 Engine Oil #2
It is fine to use it. Because your engine is not T4 you may want to shorten change interval but you will not hurt your engine. The oils are all backwards compatible.
   / Kubota MX5100 Engine Oil #3
Although many say it is fine it is a grade below the Kubota oil. Rotella is meant for over the road trucks which often are at low engine RPM's not continuous full or near full throttle use. Has a lower TBN number as well as sulfated ash is lower.
Is it okay to run it? As far as I'm concerned after the warrantee is off (so I don't have to worry about warrantee) you could put water in it and every repair shop will love you!
   / Kubota MX5100 Engine Oil #4
It is obvious that you aren't a fan of Shell products. Rotella T is just as good as any other oil of that class and advising a member that it will cause equipment breakdown it just plain wrong and saying that it is meant for over the road trucks needs some backup statement from Shell to go with your illogical rant. Why didn't you just go ahead and recommend your loved brand while at it.
   / Kubota MX5100 Engine Oil #5
I use Rotella T in four Diesel engines, including three kubota, with no problems. It is good oil
Thanks to those of you who gave serious answers to my question. I might continue to use Kubota oil, but my local dealer isn't carrying it anymore, the tractor is out of warranty and it's a long way to another dealer just to get oil. My concern was that this particular engine might be different than other Kubota engines and just wouldn't tolerate oil that included the CJ4 spec. I've used Rotella T in other, older diesel tractors and I know it's used in equipment by quite a few people, such as dirt contractors, etc.
   / Kubota MX5100 Engine Oil #7
You can use Rotella T with the same confidence as you have had with Kubota oil. All oils with that designation would be just fine and you will not damage your engine.
In an earlier post I mentioned T4 engines. I should have said Tier 4.
I have used Rotella t oil for over 20 years in everything from a gas auger engine to a 450+ hp tractor engine and truck engines. No problem. Many fleets use this oil.
   / Kubota MX5100 Engine Oil #8
Anyone have any experience with this?
   / Kubota MX5100 Engine Oil #10
I've been using Kubota oil, but Rotella is fine in Kubota engines.
NEW Woods 6ft Finish Mower (A52748)
NEW Woods 6ft...
2022 Caterpillar 906M Compact Wheel Loader (A50322)
2022 Caterpillar...
New Farm-bilt 6 Lug Running Gear (A50774)
New Farm-bilt 6...
Bobcat 3560 Skidloader Breaker (A50774)
Bobcat 3560...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
2017 John Deere TX Gator Utility Cart (A51691)
2017 John Deere TX...
