kubota mx5000 blows oil cap off
   / kubota mx5000 blows oil cap off #31
You don't want a front or rear main leak so don't run it without fixing the issue
   / kubota mx5000 blows oil cap off #33
Hose could be blocked and there has to be a check valve (PCV valve) between the valve cover breather fitting and the intake stub or the intake vacuum would cause the vapor hose to suck in oil. You might want to pull the cover on top of the valve cover and check that diaphragm too. The motor has to breathe or it will blow the oil filler cap off.
Like I said previously, I eliminated mine by running the hose down the side of the motor. I blocked off the intake nipple with a plastic pipe plug.
I put mine in the shop and they removed the valve cover and cleaned it,it has lower pressure now and the oil cap doesn't blow off.When the engine is revved up all blow by goes away!hope this helps
Mine is also a 2005 with less than 200 hours doing the same thing, ever figure out the problem? mine has alot of compression so I know it's not the rings
Put mine in the shop,they cleaned out the valve cover and the vent,it still has some pressure but not as much,hope this helps
2016 CATERPILLAR 325FL EXCAVATOR (A51246)
2016 CATERPILLAR...
50ft Fuel Line (A51573)
50ft Fuel Line...
2016 Nissan Pathfinder S SUV (A50324)
2016 Nissan...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
2005 INTERNATIONAL 4300 24FT BOX TRUCK WITH TRANSLUCENT ROOF (A52577)
2005 INTERNATIONAL...
