kubota mx5000 blows oil cap off
   / kubota mx5000 blows oil cap off #11
Engine or transmission? Common rail or mechanically injected? That will determine which crankcase breather arrangement you have.
It appears to me MX5000 has an inj pump not common rail fuel system
   / kubota mx5000 blows oil cap off #13
The OP's tractor is a PRE emissions tractor.
Accordingly to Messicks parts diagram, it can have two types of breathers. One with a PCV dumping directly to the atmosphere and another with the PCV dumbing to the intake manifold. Either way, might be a good time to pull the PCV out and check if it's clogged.
It looks like there is a hose coming out of my valve cover going to my intake manifold but I don't see a pcv valve, just a hose
   / kubota mx5000 blows oil cap off #15
Breather hoses can collect moisture and in cold climates can freeze up. The engine would then lose it's vent and would blow the cap, gasket, or seal.
Mine has a hose coming out of the valve cover and into the intake manifold, but I don't see a PCV valve
There is a little plate with 4 screws on top of the valve cover just above the hose running to the intake,could that be the pcv valve?
   / kubota mx5000 blows oil cap off #18
Yes look at pg 1 of this thread TX Jim posted the diagram for you
2023 UNVERFERTH 432 (A53084)
2023 UNVERFERTH...
2014 Dodge Charger Sedan (A51694)
2014 Dodge Charger...
Tradewinds Power Unit (A50120)
Tradewinds Power...
2021 BOBCAT T450 SKID STEER (A51246)
2021 BOBCAT T450...
2021 MACDON C3812 LOT NUMBER 34 (A53084)
2021 MACDON C3812...
