Mowing Kubota mower blades
   / Kubota mower blades #1
Bayrat
Upstate NY
Kubota B2910
I have a 72" belly deck on my 2910. Both the original blades and the extra set I purchased from the dealer came with a blunt cutting edge. The dealer is not sure if they should be sharpened, or if they are that way to add longevity and prevent chipping. I have heard some of the J/D blades come with a flat spot on the cutting edge and they are supposed to be that way. Does anyone here know what should be done with these blades? Should they be sharpened or are they better left as shipped. They seem to cut just fine, but I don't want to damage the lawn if they are intended to be brought to a sharp edge before use. No one seems to have an answer for this up to now /w3tcompact/icons/hmm.gif. The owners manual is not at all clear on this matter either!
   / Kubota mower blades #2
The blades I've looked at don't have a razor edge. They're still sharp though. As long as they're cutting without leaving ragged ends on the grass, the edge is fine. If you want a definitive answer call the Kubota corporate number in California at (310) 370-3370.
The times, I've called, I've always got a good response. You get to talk to the actual person who works in that area and not someone in customer service. That's one of the great things about Kubota, you can call them and get answers.
Great service. They answered on the first ring. The blades come ready to use, so I guess that answers the question.
   / Kubota mower blades #4
any updates with your barn Bayrat?
No Steve, just too much to do as always. If I could be away from home less than twelve hours a day, I might be able to get some wiring done. Waiting on a reply from my backhoe man as to an estimate for the 400' of trench I will need for the URD cable.
   / Kubota mower blades #6
I found this on the Canadian Kubota website a while back.
I never saw the undercut recomended anywhere else.
Mike
That is an interesting idea Mike. When I removed the OEM blades, I was surprised to see they were a bit wider than the Kubota replacement blades. The replacement parts are ground at a single angle, a bit sharper than the originals. The originals, being perhaps a quarter inch wider are ground at a lesser angle and then a second bevel is cut on the last eigth inch of the cutting edge at quite a sharp angle, almost opposite of what your attachment shows. On my machine, this edge did not hold up well and until I removed them from the machine last week, could not get a good look at them. I will sharpen to remove the second angle and return to a conventional blade, seems to work better.
2011 Mercedes-Benz E-Class Sedan (A51694)
2011 Mercedes-Benz...
2022 Toro Workman 07921 Electric Utility Cart (A51694)
2022 Toro Workman...
2014 INTERNATIONAL DURASTAR 4400 SERVICE TRUCK (A51406)
2014 INTERNATIONAL...
BUSH HOG 3308R-2 LOT NUMBER 118 (A53084)
BUSH HOG 3308R-2...
WESSEX CRX 180 LOT NUMBER 171 (A53084)
WESSEX CRX 180 LOT...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
