Kubota MMM mulching kit?
   / Kubota MMM mulching kit? #1
LGinIA
Iowa
JD X485 AWS,B2410,RTV900
I own a B2410 with the Kubota RCK60-24B MMM deck. Time of the year to start to think about mulching. I'm not aware that Kubota offers a mulching kit for this MMM. What do you recommend, special mulching blades from another source and a custom screen w/o baffles to fit on the deck? What are other Kubota owners with the 60" decks (non-BX type) using? I have a JD 445 with a mulching kit and it works great--wish Kubota offered the same for the RCK60-24B.
Am I the only Kubota owner seeking to use the MMM for leaf mulching? Although the MMM gives an excellent cut for grass, it does not do a great job on leaves. I'm looking to reduce the leaf cuts to approximately 1\4-1\2" in diameter. I mulch the majority of the leaves and pick-up the heavy excess at the end of the season. FYI-approx 6 acres with nearly 200+ trees, lots of big oaks!
   / Kubota MMM mulching kit? #3
I once inquired about using gator blades on the same deck you have. Gator blades have what looks like shark teeth on the end for mulching.
The replies I recieved were mostly negative, they didn't do a good mulching job, more hype than truth and so on. My dealer said Kubota doesn't make mulching kits for that big of deck.
   / Kubota MMM mulching kit? #4
I had those gator blades on my previous tractor which was a Simplicity and they worked great. They chopped the clipings a least half the normal size(maybe even 1/3 the size). I will most likely get them for my BX next year.
SHOPBUILT PUSH BAR FOR FORKLIFT (A52708)
SHOPBUILT PUSH BAR...
New/Unused AGT Industrial SDA-140T Track Loader (A57453)
New/Unused AGT...
Honda EM 6500 SX Generator (A55973)
Honda EM 6500 SX...
2014 PETERBILT 579 MID-ROOF SLEEPER (A58214)
2014 PETERBILT 579...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
MASSEY FERGUSON SEAT (A58374)
MASSEY FERGUSON...
