Kubota MMM mulching kit?
   / Kubota MMM mulching kit? #1
LGinIA
Iowa
JD X485 AWS,B2410,RTV900
I own a B2410 with the Kubota RCK60-24B MMM deck. Time of the year to start to think about mulching. I'm not aware that Kubota offers a mulching kit for this MMM. What do you recommend, special mulching blades from another source and a custom screen w/o baffles to fit on the deck? What are other Kubota owners with the 60" decks (non-BX type) using? I have a JD 445 with a mulching kit and it works great--wish Kubota offered the same for the RCK60-24B.
Am I the only Kubota owner seeking to use the MMM for leaf mulching? Although the MMM gives an excellent cut for grass, it does not do a great job on leaves. I'm looking to reduce the leaf cuts to approximately 1\4-1\2" in diameter. I mulch the majority of the leaves and pick-up the heavy excess at the end of the season. FYI-approx 6 acres with nearly 200+ trees, lots of big oaks!
   / Kubota MMM mulching kit? #3
I once inquired about using gator blades on the same deck you have. Gator blades have what looks like shark teeth on the end for mulching.
The replies I recieved were mostly negative, they didn't do a good mulching job, more hype than truth and so on. My dealer said Kubota doesn't make mulching kits for that big of deck.
   / Kubota MMM mulching kit? #4
I had those gator blades on my previous tractor which was a Simplicity and they worked great. They chopped the clipings a least half the normal size(maybe even 1/3 the size). I will most likely get them for my BX next year.
UNUSED JMR 40" HYD GRAPPLE BUCKET (A51248)
UNUSED JMR 40" HYD...
(INOP) NEW HOLLAND TS6.120 TRACTOR (A51247)
(INOP) NEW HOLLAND...
2008 Chevrolet Impala Sedan (A51694)
2008 Chevrolet...
Scag Mower (A50324)
Scag Mower (A50324)
2014 Chevrolet Tahoe SUV (A51694)
2014 Chevrolet...
2025 CFG Industrial MX50R (A50123)
2025 CFG...
