Buying Advice Kubota mini excavator advice
   / Kubota mini excavator advice #1
Jamie21
DARTMOUTH , ma
KUbota
Having trouble deciding between a min excavator, the kubota kx040 verse the kx057. There is roughly a $15k price difference and not sure if the step up to the 057 is worth the extra money. I have a large property where I need to dig trees and stumps, trenching, small building demo, etc. any advice is appreciated. Also any differences in residual values? Thanks!
   / Kubota mini excavator advice #2
If you don't have to transport it very often...get the biggest one you can afford. If your going to be transporting it, get the smaller one. Excavators are heavy SOB.
The six way blade is nice and very handy. Either machine will do what you describe as your needs. It's just the transportation that is the factor. The 57 will need a truck and trailer that can handle that weight. The 40 can be transported on a 14K trailer, the 57 will need a 20K trailer and medium duty truck.
I love mine and would never be without an excavator. However, I bought a smaller backhoe because the excavator is kinda a pain to drag around.
   / Kubota mini excavator advice #3
A 57 can be handled by a newer 1 ton and a 16K trailer. Nice size machine. Nice specs, looks sweet. Some guys haul a KX80 with a pick-up. Yes they are crazy and a Medium duty truck or 10 wheeler is safer.
   / Kubota mini excavator advice #4
A friend of mine has a JD 50D mini excavator. It weighs about 11,000 pounds. He hauls it on a 11 ton capacity GN trailer behind his F-250 V10. Although it's probably over the limit, it handles it pretty good. I'd sure wouldn't haul a KX80 which is about 18,000 pounds behind a light duty truck.
   / Kubota mini excavator advice #5
One of the nice things about my Komatsu PC75UUS, steel track Hyd. Thumb and some weighty other stuff, is when someone asks to borrow it, all I say is maybe, but I run machine, you pay me, and you need to move it with at least a medium duty truck and tag trailer.
It has never ventured far from my property.
   / Kubota mini excavator advice #6
I have a U55 and a KX 121. Besides the sticker price, everything is more expensive with the larger machine (i.e. Replacement Tracks). The larger machine is fantastic for pools and basements. Also keep in mind you may want more than one size bucket. Not sure what your soil conditions are like. Another difference is lift height. If you need to load anything other than a 1 ton or dumpster the larger machine is nice.
   / Kubota mini excavator advice #7
Right there Miles - need to have a bucket budget setup. Got three for my machine and more than once already I wanted another size and really want a ripper!!!
mikesee, the u55 vs 121..Do you see much difference with medium sized trees 8"-10" digging roots and pushing over? I've got a lot of basic trenching in medium soil and some tree clearing. Going to grab both 12" and 24" digging bucket. thanks!
2023 UNVERFERTH 432 (A53084)
2023 UNVERFERTH...
(2) 330 GALLON POLY TOTE (A51248)
(2) 330 GALLON...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2013 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2013 FORD F-150 XL...
JOHN DEERE 6155M (A53084)
JOHN DEERE 6155M...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A53426)
2016 FREIGHTLINER...
