Buying Advice Kubota mid-PTO
   / Kubota mid-PTO #1
Rustaferr
I want a Kubota tractor,30hp or more, but not much more than 35hp. I want a snowblower on the front so I would like a mid PTO. I am having trouble determining which units have the mid PTO or are capable of having it. Can anyone help please? :newhere:
   / Kubota mid-PTO #2
I believe if you go to Kubota.com, and look under attachments for the L series and Grand L series, you will find what you are looking for.
You might also consider the B3030, as it too offers a mid PTO, AFAIK.
   / Kubota mid-PTO #4
Kubota Tractor Corporation ==> Check each model's specification sheet. It's all there for each and every model.
   / Kubota mid-PTO #6
You may want to find out the cost of a complete front mounted snowblower before sticker shock hits. The snowblower itself is resonably priced, but add in the quick hitch, drive system, chute kit, etc and it gets out of sight in a hurry. $7,000 is not out of the question. Front mounted snowblowers are expensive regardless if they are from Kubota or the aftermarket... At least that is what I've experienced.
   / Kubota mid-PTO #7
You'll want to look at the B2920 , B3030 , B3200 , Grand L 3240, and Grand L 3540 for Kubotas in the 29 - 35hp range with mid PTOs.
And I might add to Ductapes comments, there's a world of difference between a B3030 and a GL3240, even though there's only 2 hp difference. You really need to spend time on a dealer's lot looking at models. Depending on what you are gonna do with each, the B and the L, have a lot of difference in their capabilities to offer.
   / Kubota mid-PTO #8
As long as you get a hydrostatic drive unit with the open station you can just add a couple of suicide knobs and twist slightly in the seat using a small pillow for support and easliy use a rear mount snow blower for much less money and avoid sticker shock.
For all that it matters, you could buy 2 of the JD low end garden tractors with chains wheel wieghts and soft cabs and two blowers for the money you would spend on a front mount for one of the larger tractors being L or GL models.
   / Kubota mid-PTO #9
Is this only for current models? I'm trying to find specs for discontinued older models? Any good place for that? Specifically the L4610.
Rustaferr, are you looking for a brand new tractor or a used one?
New/Unused Gold Mountain Container Shelter 20ft x 20ft (A51573)
New/Unused Gold...
2020 Steiner 450 Slope Mower (A51573)
2020 Steiner 450...
2011 Superior Trailers of Georgia Trailer, VIN # 4M8FZ1629BD000279 (A51572)
2011 Superior...
JOHN DEERE F725 LOT NUMBER 101 (A53084)
JOHN DEERE F725...
A1 MIST SPRAYERS RESOURCES TX3PT LOT NUMBER 85 (A53084)
A1 MIST SPRAYERS...
2020 COLOMBO TM LOT NUMBER 216 (A53084)
2020 COLOMBO TM...
