Kubota M9540 engine won't shut off
   / Kubota M9540 engine won't shut off
The way I would think it would work(and I could be wrong) is the fuel stop gets its power through the fuel stop relay. Because the engine continues to run, the fuel stop must be getting power from another circuit. (maybe a short from the AC blower) You could start pulling fuses with the engine running. If it stops that is the circuit that is feeding the fuel stop.
"he told me if I disconnected the fuel stop solenoid and the engine kept running then the solenoid was bad because it was staying stuck open."
This isn't the case. Correct? When you unplug the sol. the engine stops, yes?
With the ign off, there should be no voltage at the solenoid. I would guess is that you find the opposite.
The Kubota service guys are here now and seem to be stumped. They thinks there's a short somewhere because things that shouldn't have power do even if you pull the relays and fuses. They said there is a possibility that it was struck by lightning which wouldn't surprise me with the luck I've had lately!
   / Kubota M9540 engine won't shut off #22
'They think there's a short somewhere'
I would tend to agree. You are getting power when you shouldn't.
Good luck I hope the damage is small.
2016 Chrysler 200 Limited Sedan (A50324)
2016 Chrysler 200...
Land Honor Skid Steer Utility Hitch Adapter (A50515)
Land Honor Skid...
1993 Barrett Gooseneck Livestock Trailer (A50514)
1993 Barrett...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
18004 (A51691)
18004 (A51691)
2020 Nissan Rogue SUV (A51694)
2020 Nissan Rogue...
