kubota M8540HDC12
   / kubota M8540HDC12 #1
bill in ny
south central new york
kubota m8540hdc12 jd 2305 jd 4005 jd 5055e
just traded in my 06 8540 two wheel drive for this tractor. i really liked my old tractor, but with my loader i think i'll like the hydrolic shuttle better. also the cab and 4wd can't hurt either. wasn't planning on a new tractor, just stopped into the dealer to say hi and he made me a good deal on it. he gave me more for my old tractor than i paid for it new. also got cast disc wheels, one extra svc, and am fm cd radio thrown in. someone will be getting a good tractor when they buy my old one, it only has 185 hrs. on it. anyone else have a M8540HDC12?
   / kubota M8540HDC12 #2
In my mind, the 8540 is the ideal tractor and if I'd do it again I'd go w/that model over my 7040 which is an awesome machine but a bit light on it's feet for the FEL work and gen maintenance on my 127 mountain acres. Smart choice on the hyd shuttle...don't know much about the 12 speed but am sure it's a plus over conventional. in my next life I'll be riding w/u.... hats off bb
   / kubota M8540HDC12 #3
I see in the Kubota brochure the 7040 3-pt hitch is CAT I/II while the 8540 and 9540 are listed as CAT II. Does this mean you cannot use a CAT I implement on the larger tractors? I know you could use bushings on the pins, but can the arms move in narrow enough for Cat I?
Also, how does the 7040 accomdate both sizes? Does it have different size replaceable ball ends for the lift arms or do you have to use bushings? I assume you can narrow it in to CAT I by adjusting the stabilizers and then back out to CAT II as required.
   / kubota M8540HDC12 #4
Mine (7040) had a little pack of bushings with it. I don't know about the 8540 moving in enough for the Cat. I equip. I'd have to check that out before I traded up as most of my junk is Cat. I.
   / kubota M8540HDC12
I have used a few cat 1 implements with my old 8540. I had to buy some bushings at tsc. I just took it easy with them. The 8540 is a great haying tractor. I run a nine foot discbine with no trouble at all. Going up a hill with the jd bayler and a full kicker wagon, the rpm's hardley drop. And thatis in twd. They are supposed to pick up my old tractor tomorow, and bring my new one. they had to install the second svc and the cd player first. I can't wait!
   / kubota M8540HDC12 #6
Just did the 50 hour service on my M9540, 4wd, shuttle and no cab. I was going to buy a 7040 with cab, but instead gave up the cab for a bigger tractor and more HP. I absolutly love this machine, it is so nice not overworking a machine for a change.
Bake
   / kubota M8540HDC12
Bake321, what did the 50hr service run you? i think i paid around $350 two years ago on my 2wd 8540. all filters and fluid.
   / kubota M8540HDC12 #8
Bill, I had a little more than that in parts, did it myself.
Filters $64.40
Fluids $275.70
Governor $20.41
Bonding whith new tractor, Priceless!!!!!
   / kubota M8540HDC12
what is $20.41 for the govenor for. i don't remember doing anything with the govenor. is it in the manuel?
   / kubota M8540HDC12 #10
Sales tax? Spitzer hooker fund!
2008 Genie S-65 65ft Telescoping Boom Lift (A55787)
2008 Genie S-65...
2011 New Holland Boomer 90 MFWD Utility Tractor (A55301)
2011 New Holland...
UNUSED RAYTREE RMDM70 - 70" DISC MULCHER (A54757)
UNUSED RAYTREE...
UNUSED LANDHONOR HPF-11-3000G HYD PALLET FORKS (A54757)
UNUSED LANDHONOR...
2014 Nissan Juke (A55758)
2014 Nissan Juke...
UNUSED FUTURE FT15J EXCAVATOR (A54756)
UNUSED FUTURE...
