Kubota M7950 air conditioner problem
   / Kubota M7950 air conditioner problem #1
bullrun
My air conditioner quit working. The clutch is not picking up . I don't have a wiring diagram. Does anyone know where I can get a wiring diagram or can anyone tell me where to start checking?
Thanks,
   / Kubota M7950 air conditioner problem #3
Did you look at the obvious first? The wires at the compressor for connection and if it has power with a meter? Also, most A/C's have a safety switch if the freon pressure is low that does not allow the clutch to kick in.
Just a few quick checks.
Deano
   / Kubota M7950 air conditioner problem #4
The other obvious place to look is the fuse box.
Kubota RTV500 (A47384)
2007 Mitsubishi Fuso FE84D 16ft Dovetail Flatbed Truck (A50323)
2007 Mitsubishi...
2017 Nissan Rogue SUV (A50324)
2017 Nissan Rogue...
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
Farmall A Tractor w/Belly Mower (AS IS) (A50774)
Farmall A Tractor...
DIRTDOG CBX60 5' BOX BLADE (A51243)
DIRTDOG CBX60 5'...
