Kubota M7060 Problems ???
   / Kubota M7060 Problems ??? #1
Raul5452
Bronze Member
Corpus Christi Texas
John Deere 970, Kubota M7060
My Kubota M7060 is coming up on the end of warranty on June 2021. If I can extend the warranty I certainly will. If I have the money. I'm curious to know what kind of breakdowns other owners have experienced. I own a 970 John Deere and two problems repeated themselves more frequent than I cared. Four-wheel drive shaft connection point at the front axle. Had to replace end of shaft cup , ball bearings and front differential cup receiver several times. Also front steering arm ball joints would wear out and replacement of whole steering cylinder was needed 4 times. So please share your M7060 problems. I'm not to confident of the shuttle shifting tranny lasting . I have not experienced any breakdowns yet but sometimes it just does not feel very smooth. Thanks in advance.
   / Kubota M7060 Problems ??? #2
I've bought my Kubota M6040 - brand new in 2009. It has hydraulic shuttle shift. Not a moments problem with the shuttle shift or anything else on the tractor. I would suggest - forget about potential problems and just enjoy that new tractor.
   / Kubota M7060 Problems ??? #3
Two and a half years and 400+ hours on my M7060HDC12. Not one single problem to report....other than I'm always looking for a reason to get in it and do something with it! Great machine!
Thank you Oosik I have been enjoying it very much. Really appreciate your input. Very relieved to hear your 7040 has been so reliable.
Thank you Deserteagle . Good to hear such good reliability of the Kubota m7060. I just passed the 2000 hr mark a week ago..
   / Kubota M7060 Problems ??? #6
I own a '11 M7040 that has 1600+ hrs with no problems. The hyd shuttle has handled several 1000 rd bales with ""no problems"" rearing their ugly head. Only complaint I have is high/low speed selector handle on trans has been difficult to shift even with liberal lubrication of linkage.
   / Kubota M7060 Problems ??? #7
As of 1200 hours, my 2013 M7040 has had no issues, except when I picked up a piece of root with the right rear tire and it caught the cables where they go into the box for the loader controls. Bent both cable ends, and when straightening them, broke one. I replaced both cables for about 125 dollars.
David from jax
Thank you Tx Jim. Good to hear 7040s are doing great. I hope this 7060 does as well. In shifting the shuttle shifter do you use the clutch ? I don't. If I change gears I just put the shifter in nuetral , change gear and go. Do you work your tractor the same ?
Thank you Sandman . Read my response to txjim please. Do you just shift back and forth with out the use of the clutch too ? I'm not having tranny problems. I'm just curious if I'm abusing the tranny.
   / Kubota M7060 Problems ??? #10
I bought my M7040 with cab, hydraulic shuttle 4wd about 12 years ago. I sold it about 5 years ago, so in ~7years of use (baling hay, shuttling dirt from grading foundations, running a Harley rake, carrying pallets of block, bags of mortar, etc) it never failed me.
I would say it might be one of the most simple, reliable tractors I ever owned. Just change the filters as recommended, keep the fittings greased and run quality fuel and oils in it and itll run a long, long time.
2018 Bobcat T595 (A50120)
2018 Bobcat T595...
2003 Lincoln LS (A50324)
2003 Lincoln LS...
2008 Nautica International RIB 24ft Cat Boat with T/A Boat Trailer (A50324)
2008 Nautica...
2014 Volkswagen Passat Sedan (A50324)
2014 Volkswagen...
2013 Ford E-250 Cargo Van (A50323)
2013 Ford E-250...
Pequea HR10 Rotary Rake (A50774)
Pequea HR10 Rotary...
