Kubota M7040 with Loader hydraulic connections
   / Kubota M7040 with Loader hydraulic connections #11
Mine doesn't have that little switch, mine has a switch up on the top side of the handle for the loader. It diverts pressure electrically when it is pushed, and from what I can tell, doesn't do anything when it isn't pushed.
Thanks for the picture Ovrszd!!
David from jax
Without a pic, I'm just guessing.... I think you have a diverter valve operated by that single push button. It ues the bucket curl function to curl (button released) to 3rd function (button pushed) but can't do both at once.
   / Kubota M7040 with Loader hydraulic connections #12
Appreciate the help!! I'll hook up the grapple tonight and give it a go.
   / Kubota M7040 with Loader hydraulic connections #14
Yep, sounds about right. Thanks!!
David from jax
   / Kubota M7040 with Loader hydraulic connections #15
Hmm......so many different ways of doing it. I have the WR Long, electric over hydraulic system with a toggle switch on the FEL handle.
   / Kubota M7040 with Loader hydraulic connections #16
A self cancelling toggle that returns to normal function?
   / Kubota M7040 with Loader hydraulic connections #17
Yes - You have to hold the toggle in the up or down position. Let go - it returns to the center (OFF) position.
The system works great. I've learned how to "modulate" a direct on/off system - with quite a bit of practice.
Only improvement I would suggest - make to toggle protrude further from the FEL joy stick. Its difficult to activate the toggle with heavy winter gloves on.
   / Kubota M7040 with Loader hydraulic connections #19
I would venture to say that pic #4 is your new FEL control handle. Somewhere up on the top of that top knob there should be a button or toggle that controls - grapple open/grapple closed. Understand the third function system only provides ONE extra function - grapple open and grapple close. The remainder are the same as if you had the bucket on the FEL - up/down and roll forward/roll back.
I have a fantastic pic of the top of my control handle with toggle switch. UNFORTUNATELY - the gods of technology are saying "you do not have authority to perform this function". I WILL send the picture to you golfgooroo thru other avenues.
Its just simply not going to allow me to upload any pictures. What a true PITA!!!
   / Kubota M7040 with Loader hydraulic connections #20
If you have one button/switch, you have a diverter valve system. If you have two buttons/switches you have 3rd function.
The first performs a function in lieu of a different function. The latter performs a 3rd function in conjunction with the others.
2012 Ford Escape XLS SUV (A51694)
2012 Ford Escape...
2012 Ford Edge SUV (A50324)
2012 Ford Edge SUV...
Heritage / Woods RD 72 3 pt Finish Mower (A50515)
Heritage / Woods...
8' GREEN CHAIN LINK FENCE (A51244)
8' GREEN CHAIN...
91013 (A48082)
91013 (A48082)
UNUSED CFG INDUSTRIAL PD680-PZ POST POUNDER (A51244)
UNUSED CFG...
