General Lee
Veteran Member
There is an "L" bracket at the top of the adjustable side leveling rod. This bracket is spring loaded and you have to lift it up to hand screw the rod to level an implement. Problem is you need one hand to hold it up leaving you with just one hand to turn the rod. Most times you need both hands to turn the rod, but this "L" bracket, when down acts like a lock nut, catching the handles on the adjustment rod. If this bracket indeed is supposed to act as a lock nut, is there something missing that is supposed to hold it in the up position? I can post a pic if needed.
