Kubota M7040 FEL boom slow sometimes lowering.
   / Kubota M7040 FEL boom slow sometimes lowering. #1
Tx Jim
New Member
Coyote Flats,Tx
JD 4255/Kubota M7040 HDC
Yesterday I was handling some rd bales with my tractor with 1591 hrs & noticed after I moved a few bales the boom would get slower going down then it would return to normal speed. If I moved joystick to float position the boom always lowered much faster. Movement of joystick feels the same as it always has so I think cable is not the problem but I won't rule it out. I haven't changed the hyd filters in several 100 hrs of operation so I'll perform that task today but I would think clogged filters would also affect speed of lifting & power steering which doesn't seem affected. I'm also going to disconnect quick couplers on FEL & reattach although I have never removed FEL since I purchased tractor in 2012.
Thanks for any ideas or solutions,Jim
   / Kubota M7040 FEL boom slow sometimes lowering. #2
Filter won't do that.
Coupler would be a good start. Uncouple and recouple first. If still has problem, swap the hoses. That will tell you if it's that hose/coupler.
Interested to hear the results.
   / Kubota M7040 FEL boom slow sometimes lowering. #3
I’d also check/adjust the cables. At1500 hrs it’s worth a look- especially if float causes the speed to correct.
Thanks for replies. My employee moved about 40 rd bales yesterday & stated FEL lowered correctly from initial engine start up until finished so I didn't perform any diagnostics. This seems very weird! I guess I'll see what it does this afternoon.
Thanks,Jim
   / Kubota M7040 FEL boom slow sometimes lowering. #5
Glad it's working. I had to adjust my cables once a couple years ago. It was the curl circuit. Just wasn't smooth and consistent. I don't recall having to make much change. I'm just over 1500hrs.
2017 Ford F-450 Altec AT200A 30ft Bucket Truck (A50323)
2017 Ford F-450...
20' Deer Gates (A50121)
20' Deer Gates...
2016 JLG 3248RS 32ft Electric Scissor Lift (A50322)
2016 JLG 3248RS...
T3 Motion Patroller Segway (A51694)
T3 Motion...
New/Unused 10ft 40 Drawer Workbench (A51573)
New/Unused 10ft 40...
2010 Hyundai Elantra Touring Sedan (A51694)
2010 Hyundai...
