Kubota M6800
   / Kubota M6800 #1
srparrish85
I have a 2001 M6800 4wd and plan on changing all the fluids this weekend but I have lost my owners manual and really not interested in buying a new one. I have a few questions: 1. How many gallons of hydraulic fluid does this tractor hold? 2. How much oil will it hold and what is the recommended weight? 3. What type/weight oil is in the front axle with the 4wd.?
   / Kubota M6800 #2
There's a spec page here that shows trans and engine capacities. If your front axle is dry (no leaks) then drain it into a clean bucket and put the same amount of new oil back in.
Lots of opinions out there about which oil to use. At a minimum, engine oil should be name brand 15w-40 diesel-rated. Transmission oil (hydr fluid) can be from Agway (cheapest), up to Kubota-brand SUDT. Front axle takes 70w-90 gear lube.
Your tractor is worth maybe 20k - maybe good to spring a few bucks for an owners manual ? Just a thought.
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2025 INDUSTRIAS AMERICA 227T 7' X 22' HYD TILT TRL (A51247)
2025 INDUSTRIAS...
2019 HINO 195 16 FT BOX TRUCK WITH LIFT GATE (A53426)
2019 HINO 195 16...
4 Drums of Fabric Softener (A51573)
4 Drums of Fabric...
UNUSED CFG INDUSTRIAL MH12R EXCAVATOR (A51247)
UNUSED CFG...
2016 KENWORTH T270 S/A SERVICE TRUCK (A51247)
2016 KENWORTH T270...
