Kubota M6800 Starter Sparking
   / Kubota M6800 Starter Sparking #1
dockalmbach
lincoln, tx
kubota m6800
Have 2002 kubota M6800. Bought 3 yrs ago. Started a few days ago with no problem. Drove to a neighbor and stopped it. Tried to start again and only have a click in the starter solonoid. Put charger on battery and it showed 50% charge and the battery is the same one that came with the tractor to me. When the battery was charged same click the first try then the second try some sparks flew off the starter and then it started. The wires all appear to be tight. Brought it home and same thing. Starter will turn when solonoid manually engaged but the tractor will not start.
Any suggestions? Bad starter, voltage (battery) issue?\
Any help would be appreciated.
   / Kubota M6800 Starter Sparking #2
I've melted the ground cable between a starter and frame before so I suggest checking that. Disconnect the cable from the frame, check cable for cracks or damage, clean both the cable and frame ends, replace the serrated washers, reconnect the ground cable and see if that makes any difference.
   / Kubota M6800 Starter Sparking #3
Disconnect the battery from the cables and use a battery tester to check the battery, or take it to one of the auto shops that sells batteries to test it. It sound like your battery may take a charge, but not a complete one. It may have (a) bad cell(s). If the battery is OK it most likely is the starter. I am not familiar with the starter on your tractor, but if it has a solenoid, it may be failing as well.
   / Kubota M6800 Starter Sparking #4
Check the cables at the starter and battery to make sure they are clean and tight.
John Deere D110 Ride on tractor mower (A49461)
John Deere D110...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
2018 DODGE GRAND CARAVAN (A51222)
2018 DODGE GRAND...
2015 Peterbilt 579 (A49461)
2015 Peterbilt 579...
1984 AM GENERAL HMMWV HUMVEE (A51222)
1984 AM GENERAL...
AMG M 35A2C drop side 2 1/2 ton 6 x 6 (A50323)
AMG M 35A2C drop...
