Kubota M6800 hydraulic whistle?
   / Kubota M6800 hydraulic whistle? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I have a new-to-me Kubota M6800 with 400 hours that I bought at an estate sale. In starting to use it, I noticed a very faint "whistle" that almost sounds like a fan belt that is slipping a tiny bit. I changed the belt. It has a loader but it's not on at the moment.
The tractor needs to warm up and then I hear this slight whistle. If I push the joystick lever one way and hold it, the whistle seems to go away. A couple times I made the whistle go away by using the hydraulic remotes (that were hooked to a cylinder). I worked the hydraulic levers and joystick just to make sure nothing was sticking.
Also, I put my mechanic's stethoscope on the pump and I can hear the whistle in there. Any idea what's going on or what to do next? I have no idea.
Here's what the problem was. The draft control adjustment rod had come loose and lengthened itself a little bit longer and that, it turn caused the very slight hydraulic whistle.
   / Kubota M6800 hydraulic whistle? #3
I'm glad you located the cause of the whistle sound. Noise you heard was probably 3 pt relief valve being pushed off it's seat.
2007 FORD F-550 XL SUPER DUTY DUMP TRUCK (A51406)
2007 FORD F-550 XL...
King Kutter Rotary Tiller Tractor Attachment (A51691)
King Kutter Rotary...
2018 John Deere R4038 Sprayer (A53342)
2018 John Deere...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
2010 Nissan Sentra Sedan (A51694)
2010 Nissan Sentra...
