Kubota M6800 hydraulic whistle?
   / Kubota M6800 hydraulic whistle? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I have a new-to-me Kubota M6800 with 400 hours that I bought at an estate sale. In starting to use it, I noticed a very faint "whistle" that almost sounds like a fan belt that is slipping a tiny bit. I changed the belt. It has a loader but it's not on at the moment.
The tractor needs to warm up and then I hear this slight whistle. If I push the joystick lever one way and hold it, the whistle seems to go away. A couple times I made the whistle go away by using the hydraulic remotes (that were hooked to a cylinder). I worked the hydraulic levers and joystick just to make sure nothing was sticking.
Also, I put my mechanic's stethoscope on the pump and I can hear the whistle in there. Any idea what's going on or what to do next? I have no idea.
Here's what the problem was. The draft control adjustment rod had come loose and lengthened itself a little bit longer and that, it turn caused the very slight hydraulic whistle.
   / Kubota M6800 hydraulic whistle? #3
I'm glad you located the cause of the whistle sound. Noise you heard was probably 3 pt relief valve being pushed off it's seat.
2017 VOLVO VNL SLEEPER (A52577)
2017 VOLVO VNL...
30 Yard Roll Off Container (A51573)
30 Yard Roll Off...
JOHN DEERE 3040 TRACTOR (A50459)
JOHN DEERE 3040...
1272 (A50490)
1272 (A50490)
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
2017 John Deere 8345R MFWD Tractor (A53342)
2017 John Deere...
