Kubota M6800 how large can I go on the mower?
   / Kubota M6800 how large can I go on the mower? #11
moloss said:
I would assume a pull behind would get me more width but what's the widest y'all would go? I use a 7 foot finish mower right now (when not getting someone to cut hay) on fairly flat fields.....I'm looking to cut (pun intended) my mowing time down......thanks Chris.
We pull a Rhino SE15-4 all the time with a JD2755 and clip pasture with a JD2355.
Horsepower Required-50 HP
   / Kubota M6800 how large can I go on the mower? #12
my brother has an m6800 and pulls a 10 ft hog fine. we have talked about trying my 15 foot cutter on it but thats as far as we've gotten so far.
   / Kubota M6800 how large can I go on the mower? #13
Thought I'd relate my experience from Friday. I'm a newbie with about 40 hours M6800 seat time, I've got to get that out of the way first.
I found a good deal on a HD 8' mower, that apparently weighs just over a ton. (2035lbs), Brought my M6800HDF, R4 tires (not filled), and attempted to pick it up and immediately found my front tires about a foot off the ground. It's an experience trying to drive with the front end in the air, trying to steer with the rear brakes.
Tried for a while to get it loaded up on a trailer, but I ended up not bringing it home with me.
It would pull it around just fine, and it had the strength to lift it, but I wish I had purchased a FEL or something to counter all that weight back there when you need to lift it.
Weight seems to be a large consideration with a 3pt lift style, to me.
I should probably start another thread and ask for advice. It may be the problem was just me and inexperience.
fwiw,
Brad
   / Kubota M6800 how large can I go on the mower? #14
fwiw,
Brad
Ummm, that's why they make front weights
You gotta have some weight up front to counteract all that weight in back
   / Kubota M6800 how large can I go on the mower? #15
Yeah, I'm feeling pretty stupid, but thought I'd post my experience in case it helped the original poster's question or any other M6800 owner. I thought the specs on the lift indicated I would be OK.
   / Kubota M6800 how large can I go on the mower? #16
You are not clear what type of cut you want or what you are cutting. Depending on what you are cutting and the results you wants a disc mower used in hay might be an option for you.
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A56436)
Michelin CARGOXBIB...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2007 Ford F-350 9ft. Stakebody Flatbed Truck (A55852)
2007 Ford F-350...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A56436)
2019 Krause...
