Kubota M59 front hydraulics for snowplow?
   / Kubota M59 front hydraulics for snowplow? #1
bravo5
PA
Kubota M59
Can I use the front auxiliary hookups to power angle my western plow? Or do I need a diverted or flow control valve(s)....
Got the answer! The front auxiliary hooks work the power angle on the plow with no flow control needed. The angle works faster than a normal set up, but still works great. Only modification needed was adapting the fittings
   / Kubota M59 front hydraulics for snowplow? #3
A flow restrictor of some sort is helpful. I use automotive brake hoses. The small line size does the job perfectly.
   / Kubota M59 front hydraulics for snowplow? #4
Did you use steel braided brake hoses or or regular rubber brake hose?
They better be steel braided for the cost of them��. How can I tell??
   / Kubota M59 front hydraulics for snowplow? #6
Stainless braided would not have a black rubber coating. I'm not sure about after market hoses but OE rubber brake hoses are not compatible with mineral oil based fluids. It will destroy the rubber. I work in brake development and have seen the results of people who put motor oil, trans fluid, power steering fluid, etc in the master cylinder reservoir, several thousands $ . It would be best to have napa or other company make you a set small diameter hydraulic hoses or run just run it through some brake pipe
Dave
Here's a pic. I got them made at our local tractor dealer and explained what they were for. I'm going to look at them tonight again. Thanks for the advice though!!
   / Kubota M59 front hydraulics for snowplow? #8
If you had them made at your dealer they are hydraulic house rated for the right fluid their is probably a steel braid in the rubber. Which you can not see
Dave
Thanks again!
   / Kubota M59 front hydraulics for snowplow? #10
cushion valve in circuit can be a lifesaver
2022 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
UNUSED FUTURE FT-E48 ELECTRIC BICYCLE (A51244)
UNUSED FUTURE...
2000 Ford Ranger (A50515)
2000 Ford Ranger...
2014 Yale 3 stage 8500lbs lift solid tire forklift (A52128)
2014 Yale 3 stage...
`2021 CATERPILLAR 246D3 WHEELED SKID STEER (A51242)
`2021 CATERPILLAR...
UNUSED FUTURE PAIR OF MINI RUBBER TRACKS (A51244)
UNUSED FUTURE PAIR...
