Kubota M4800SU won't start - checked starter, checked battery
   / Kubota M4800SU won't start - checked starter, checked battery #1
thsteger
Cookeville, TN
Kubota M4800SU
Hi. I worked with my tractor about 15 mins last week (fired right up, as always), stopped it, turned it off and did some other things. Jumped back on a couple hours later and it wouldn't start. It doesn't turn over far enough to fire. It turns just enough to see the fan move, then stops. Seems like the starter doesn't have enough power to keep it turning.
I had some starter problems last year that I had fixed, so I took it to a different starter repair guy who said that the clutch pack was worn out and fixed it for a little over $100. He said all the electrical components were fine. Put it back on and the same thing happened, so I took the battery off and had it checked. It's good. What should I check next?
Thanks,
Thom
   / Kubota M4800SU won't start - checked starter, checked battery #2
Have you cleaned & tightened all 4 battery cable connections??
   / Kubota M4800SU won't start - checked starter, checked battery #3
X2. This is the next step. I actually make it my first step. You can lose a lot of current through resistance at poor connections.
New 3pt Sod Cutter (A50774)
New 3pt Sod Cutter...
2015 Ford F-250 Ext. Cab Knapheide Service Truck (A50323)
2015 Ford F-250...
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50775)
ALL TITLED ITEMS...
John Deere Gator 825i 4x4 Utility Cart (A50322)
John Deere Gator...
2' Auger Extension (A50774)
2' Auger Extension...
7021 (A50322)
7021 (A50322)
